Where to Start?
Old Oct 24, 2018 | 08:34 AM
TheBigBlueBoat's Avatar
Where to Start?
I just recently got my 70 back into my hands and it's got a whole lot of rust in the back end. It needs at a minimum:
Quarter panels
Trunk pan
Trunk drop offs
Outer wheel houses
Now that's the better part of the back of the car, and all those parts fit together. The question is what order do you think would be best in order to keep the body as true as possible? I've done plenty of body work before, but never so many adjacent parts at once. Really it all comes down to the quarter panels since they're the most visible. Is it better to do them first and reference them to the original sheet metal, or do them last to allow fine tuning of the resulting body lines?
Old Oct 24, 2018 | 09:55 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Do some homework. There is an order of operation for extensive surgery, both upon cutting it apart and reassembly. Measurements need to be recorded prior to any cutting.Things need to be supported prior to any cutting. Panel gaps need to be established at the fit-up/tack weld stages etc...Proper tools need to be purchased such as spot weld drills, good MIG/TIG welder and auto dark helmet, 42 thousand welders vice grips, glass removal suction cups etc etc...Not a job for the meek or untrained. Try YouTube.
Old Oct 24, 2018 | 12:01 PM
I'm well equipped and familiar with the work. However even in my body days I never came across a hard and fast rule of what to replace first in this sort of case. Usually everything had to be tailored to that specific installation regarding access and what mounted to what. That and the fact that a car as far gone as this one would have been in the crusher already.
That said I think I'm leaning toward the approach of quarters first, then trunk, given the trunk drop offs are fairly intact combined with the existing sheet metal should give me a fairly precise location for the new quarters. The lower quarters have all but disintegrated so doing it the reverse way would leave me with an unknown point for the quarters.
Old Oct 24, 2018 | 01:36 PM
I like to start with the hardest first, trunk and drop-offs. After that its all down hill.
Old Oct 24, 2018 | 04:04 PM
therobski's Avatar
I did replace the trunk pans and braces, partial wheel housings before we pulled the body. Helped kept anything from moving in terms of structural movement causing fitment issues. Few pics for inspiration!! AND the car is not finished yet ( are they ever)
Old Oct 24, 2018 | 05:13 PM
Nice job!
Old Oct 24, 2018 | 06:46 PM
lshlsh2's Avatar
71 cutlass convertible
I have started with patch panels from a parts car. They have the trunk drop offs still attached. Life has come up and have not done anything lately. Have started a thread, hope to get back to it soon. I will end up doing part of the trunk then the quarter panel, I think.
https://classicoldsmobile.com/forums...nvertible.html
RandyS
Apr 22, 2013 06:17 AM
815Cutlass1972
Body work
19
Jan 6, 2013 09:52 AM
jon 72 442
Body work
Feb 26, 2011 06:34 PM
ScottMHoffman
Body work
May 18, 2010 04:48 PM
woodie582
Body work
Oct 27, 2009 04:13 PM
