Best Practices - Order of installation body panels
Old Apr 17, 2013 | 12:14 PM
RandyS's Avatar
I have been busy doing surgery on my 66 442, removing the rusted out pieces of the lower rear quarter panels, dropoffs and trunk pan. I have new parts ready to weld in, and I am looking for guidance on the best place to start. The trunk pan I have is individual pieces, not a complete pre-made unit. I am thinking it might be easier to weld up the trunk floor sections and bracing before installation? Looking for whatever guidance you can provide (yeah, I know, take it to the body shop and let them do it). I am one of those committed (or should be) do it yourselfer's, just wind me up and point me in the right direction. I can weld, and have done body work, just never this large a project from scratch.
Thanks,
Randy
Old Apr 18, 2013 | 05:14 AM
RonFX's Avatar
major work
Randy:
I am at the same point in my body off resto of my 66 Cutlass, I would really like opinions of some of the guys who have done this before.
Thanks Ron
Old Apr 18, 2013 | 04:52 PM
RandyS's Avatar
Well Ron, looks like we're on our own.............
Old Apr 18, 2013 | 04:58 PM
Mikes65's Avatar
I think you will get a better fit in the trunk pan putting the 2 outside pieces in and the the center. That is how i did mine and i think trying to get thepeice installed in 1 piece would be difficult. I was worried about placement of the braces but with careful measuring mine lined up perfectly- I did a frame off.
Old Apr 18, 2013 | 05:21 PM
coppercutlass's Avatar
Chevy budget Olds powered
shoot guys im a body man
Old Apr 18, 2013 | 05:23 PM
Mikes65's Avatar
How is this-
Old Apr 18, 2013 | 05:28 PM
looks very nice i would add some more welds around the inner wheel housing to the truck floor are and i would also add a few more welds in between the welds. grind them down. then care fully brush seam seal over them after you add a good primer over the welds. I like to tape off the areas i dont want seam sealed so i can get a nice even uniform look. You can also just add enough tac welds to cover it all up and just grind em down which at that point no seam sealer would be needed. it's personal preference.
Old Apr 18, 2013 | 05:37 PM
RandyS's Avatar
Thanks for the tips. Since we have the lower quater panels removed, would the flow go - floor pans, then dropoffs, then quarter panel patches?
Old Apr 18, 2013 | 05:44 PM
The way i like to do it is center out back to front. So yes rear trunk , then drop offs, then quarters then you hang your doors and align them then put your fenders on and align them the the hood. Now only if it was that simple lol. I would put the center piece of the floor in sheet metal screw it in place then your side pieces then your drop offs. once you get everything where it should be leave the screws in to hold things in place start welding remove the screws and weld the holes shut.
Old Apr 19, 2013 | 12:31 PM
Mikes65's Avatar
I totally agree and have proved this assembly as coppercutlass recommended. Be aware the repop drop offs sold for the cutlass are generic, possibly based on chevelle dims so it is a couple inches short. I cut mine in half and installed front and rear and made a piece to section in.Again it came out pretty nice with some patience.
Old Apr 19, 2013 | 01:33 PM
Mikes65's Avatar
My frankenstien rear qtr patches. Sectioned old front fenders for the wheel lip and then i had some stainless I bent to fit the rear.
Old Apr 19, 2013 | 02:40 PM
RandyS's Avatar
Talking
I was able to find a set that are the correct size.
Old Apr 20, 2013 | 07:05 PM
Mikes65's Avatar
Randy
Please post the source and p/n
I couldnt find them although it was 2010 and more and more repops are available
Old Apr 20, 2013 | 09:42 PM
RandyS's Avatar
[QUOTE=Mikes65;537155]Randy
I couldnt find them although it was 2010 and more and more repops are available[/QUO0TE]
The Company is CARid. Here is a link to the item: http://www.carid.com/1966-oldsmobile...nks-tailgates/
Their prices are good too.
Old Apr 22, 2013 | 06:17 AM
Mikes65's Avatar
Mine is a 65 the Goodmark drop offs listed say 66
Mine looked the same as pictured and were Goodmark but were short
Hairy Olds
Sep 1, 2015 02:05 PM
jfb
Jun 15, 2015 06:33 AM
madmax442.com
Mar 24, 2014 05:21 AM
QMaster
Feb 22, 2012 09:10 AM
sandman357
Aug 11, 2010 10:28 AM
