Trunk pan - patch or replace?
have a 72 Cutlass Convertible. Replacing body bushings and found significant rust where the wheel wells and trunk pan come together. If looking at the tire, the rust in from about 1 to 3 o'clock runs about 8-10 inches and .5 inch wide. Do I need to do replace the entire pan or is there any way to patch?
thanks,
Scott
thanks,
Scott
Didn't get the pics
See if this helps
When you reply make sure you are in “Advanced” If it says post a “Quick reply” hit “Advanced”
Scroll down below the box you type in and hit “ Manage Attachments” A new box will pop up.
Hit “Browse”
The hit “Upload” and wait a few secs for the pics to up load. Then close this box.
Next you can hit “Preview Post and your pictures should be there.
There is a size limit on pics
See if this helps
Hit “Browse”
I'll give you my 2c opinion.
I'm not a big fan of the 3 piece trunk floor repair kit, but sometimes you need to use them, you may be able to use a portion of it and save some of your trunk. I'm not a big fan of replacing huge amounts of good original metal, but sometimes you have to do it. It's impossible to know until you fully investigate it, I've had alot of cars with the damage shown in the pics and was able to bend and form my own repair panels. A good body man will be able to repair the rusted area inside the wheelhouse as well as the area in the trunk around the wheelhouse but if rust has spread beyond those areas plan on a new trunk floor.
Good luck
Good luck
What about the 1 piece trunk kit on yearone.come? My trunk bottom also needs to be replaced. I'm just not sure how much of it. I am in japan on a 10 month deployment but will be home in 4 days to do some more loooking in the trunk.
We just did this on my sons Chevelle.It is not as easy as you think, and the one piece replacement, did not line up good. It took us al long time to do, and had to change, a lot to make it match the original trunk. So what I would say, is if you only have a little bad area, just replace it, not the hole trunk, even if you have to buy a complete trunk replacement, only replace what you need to. Also if you replace the hole trunk bottom, you will not believe how many spot weld holds it in place.
AzChevs
October 19th, 2014 09:03 PM
