Trunk Brace?
Old Jun 28, 2015 | 09:32 AM
Chuxter's Avatar
1970 Cutlass Supreme
Trunk Brace?
Hopefully the attachment is here but Im looking for a new Brace that goes across the bottom of the trunk that the last set of body mounts sits on. Is this part available or are we looking at a donor car situation or has anyone ever fabricated one?
Old Jun 28, 2015 | 10:21 AM
oldspackrat's Avatar
I or probably a few others on this site will have that part. I'm going on vacation tomorrow & will be gone for about a week or I'd get pix for you. I'm sure someone else will post soon but if not, contact me next week?
Old Jun 28, 2015 | 11:11 AM
AzChevs's Avatar
I have one off and ready to go that was taken off the spot welds, no rust and mounting nuts are nice. The only problem is a small section in the middle top edge was cut with the tail panel by the previous owner.
Old Jun 29, 2015 | 07:06 AM
Chuxter's Avatar
What do you want for this piece and any idea shipping price to 64505?
Old Jun 29, 2015 | 12:12 PM
68442's Avatar
Yes, This part is available brand new aftermarkert
Old Jun 29, 2015 | 12:57 PM
Chuxter's Avatar
Through who? Part#
Old Jun 29, 2015 | 01:33 PM
68442's Avatar
I don't have a part number But They have them listed on ebay. BTW the GTO uses the same. if this helps your search. ebay Number#390286487274 The only reason this is not listed for a cutlass is it has 2 1/2"punched holes not used for a cutlass. I have used these on cutlass's personally on a 68 and a 70 442
Old Jun 29, 2015 | 01:52 PM
68442's Avatar
http://www.championclassicauto.com/q...3351_3410.html
Here is one for a 69 chevelle that is also the same
Old Jun 29, 2015 | 01:53 PM
Chuxter's Avatar
So This fits it just has an extra set of holes? I looked it up and even called Tamraz and they had no Idea
Old Jun 29, 2015 | 01:57 PM
68442's Avatar
http://www.ebay.com/itm/1968-GTO-Old...-/181083462022
Here is another one on ebay
Compare it to yours
This one i see doesn't even have the holes i mentioned. so this is is even better
I just did a 70 and found the part to be identical other than two small holes. I can take a photo of it on my car as the car is still apart if you want.
Old Jun 29, 2015 | 02:07 PM
68442's Avatar
My point with the holes is you see on your picture the holes to the left and right of where the filler neck would be? On the cutlass these are not used so they are just holes. But on the GTO they are used and have a threaded nut behind the hole.
Old Jun 29, 2015 | 03:13 PM
70vert's Avatar
I used one in my 70 convertible and it was identical. The only difference was the new one didn't have the little hole for the filler neck support.
Old Dec 6, 2017 | 02:44 AM
armycav0's Avatar
so glad I found this post as it is going to save me the headache of fabricating a part of this!!!!!
musicars
Body work
Aug 15, 2013 09:32 PM
Ranzan
Jan 30, 2010 01:52 PM
redvettemike
May 31, 2009 04:47 PM
Cutlass69S
Oct 22, 2008 07:57 AM
lil_no
Feb 11, 2008 12:41 PM
