Stripping to metal ?
Old Aug 5, 2011 | 02:06 PM
CLcutlass's Avatar
How long can you leave the car stripped to the metal ?
What seems to work the best...I just did a door with 60 disk on a grinder it was quick but some heavy scratches. I think that I will tyr 80 DA on top of that.
Any suggestions ?
Old Aug 5, 2011 | 02:24 PM
Depends on where you are...
Here in the Northeast, about two hours.
In Arizona, probably about twenty years.
Any suggestions ?
SIXTY?!?
Wow. You're a brave man.
You'll be filling gouges for weeks.
Use a Scotchbrite-type stff rotating paint removal pad and you'll be much happier, and save the 60 grit for grinding diamondplate. I've made that mistake. I know.
Old Oct 2, 2011 | 07:21 PM
65 Delta Guy's Avatar
Media blast??
Old Oct 2, 2011 | 07:29 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I have used aircraft stripper before but you better have some good ventilation and that stuff is nasty but it works. I would check on soda blasting. I have never used it but I have only heard good things about it.
hilbily
Body work
Sep 9, 2014 08:54 PM
brent
Oct 3, 2011 07:47 AM
Cameo White
Sep 12, 2009 12:49 PM
texasred
Apr 19, 2004 01:07 PM
