Stripper
Old Jun 22, 2025 | 07:21 AM
Chuxter's Avatar
1970 Cutlass Supreme
Stripper
What is the best way to strip a hood down to bare metal?
Old Jun 22, 2025 | 05:59 PM
OLdGreenPaint's Avatar
Its kind of a Pick your Poison type of thing. This link details most of the options.
https://ahhgaragetime.com/automotive-paint-stripping/
My default method is chemical stripping, followed by 120 DA grit down to the metal. Least amount of dust, but gooy messy. EPA outlawed methyl chloride strippers, so they generally do not work nearly as well as before. Jasco is the best I have found. Scuff up with 80 grit, slather it on, cover with thin poly sheeting. Wait an hour, I am using razor blades in a tool holder.
Have not tried the abrasive stripping machines. I would be concerned about heat generation.
Sandblasting works good, if you have equipment and an area to do it in. If you are doing underside of hood, that would be a good option, with all the reinforcements, nooks, crannies.
Just my 2 cents worth.
MX442
Oct 21, 2024 01:33 PM
F-85 4-4-2
Apr 23, 2024 12:35 PM
Rob64cutlass
Feb 20, 2024 04:14 PM
James J
Nov 14, 2023 05:09 AM
gbledsoe3
Body work
19
Nov 9, 2016 10:53 AM
