How to recoat the Fiberglass Hood scoop on 84 H/O
Old Nov 13, 2023 | 05:08 PM
James J's Avatar
The hood scoop on my car is down to the fiberglass strands. What product do you put on it to give it a smooth surface again? I think it's called Gel coat. The wing is bad too but they make new ones of those. Thanks Jackson
Old Nov 14, 2023 | 05:09 AM
chopolds's Avatar
You 'can' re-gelcoat it. You need a special gelcoat gun, as well as the gelcoat. It will go on thick, and not so smooth, so you'll have to do lots of sanding afterward to make it nice. Another option, the one I most often use, is to put on a high build epoxy primer. Easier to find, easier to use, with a standard primer spray gun, and easier to sand smooth afterwards.
ajr2820
Body work
Jan 1, 2024 09:20 AM
455man
Body work
Mar 27, 2013 02:07 PM
vista cruiser 1
Jul 9, 2012 08:15 PM
old tired rebel
Body work
Nov 10, 2009 06:05 AM
