sanding block
Old Sep 7, 2025 | 12:14 PM
Chuxter's Avatar
1970 Cutlass Supreme
sanding block
What is the best sanding block to use when sanding imperfections out of clearcoat?
Old Sep 7, 2025 | 01:56 PM
66-3X2 442's Avatar
If you want the best use a steel block. Use a 2" x 4" piece of steel bar and round the corners off so they won't dig in to the paint. Wrap the sandpaper around the bar. Probably a 3/8 or so thickness will work. Let the weight of the bar do the work but you can use a little pressure. It works great on orange peel or cellulite leg waves. For those who say BS, try it and see what the results are. You can use a 1 1/2 bar too if that's what you can find. I had a buddy who was one of the best painters you could find and I told him about this method and he even started blocking primer using this method. He couldn't believe it. I can't take credit for this, the credit goes to 66442 for telling me about this. He painted my car & 2 of the 66 W30's who won Best of Class and Gold @ the MCACN.
Old Sep 7, 2025 | 02:22 PM
Solid bar, Mike?
Old Sep 7, 2025 | 04:25 PM
66-3X2 442's Avatar
Solid bar, Mike?
Yes. just a piece of solid flat bar. My buddy made one out of aluminum that he used.
Old Sep 7, 2025 | 07:28 PM
Ok, might try that.
Old Sep 8, 2025 | 12:10 AM
Andy's Avatar
Aluminum sounds good, little lighter. I will check this out as I planned to use a piece of hardwood.
Jul 9, 2019 09:27 AM
65Delta
Aug 22, 2017 06:10 PM
Octania
Apr 7, 2016 02:51 PM
olds_freak
Apr 29, 2015 08:23 PM
whiskey runner
Mar 22, 2014 11:45 AM
