patching rust
Old Mar 2, 2010 | 02:11 PM
bigwillystyle's Avatar
new user
patching rust
I want to fix a bad rust hole on my 71 olds cutlass but i dont know were to start. the hole is on the drivers side quarter panel and it is rusted through the panel and through the wheel well. what should i do?
Old Mar 2, 2010 | 08:41 PM
Mikes65's Avatar
Check out OPGI.com They are in California and they should have the inner and outer patch panels for that year. If you are going to weld them and you are not an expert i recommend drilling a series of holes about 1/2 inch from the edge and spot welding. This is so you don't create a weak spot around the perimeter of the repair by trying to weld all the way around.
Old Mar 3, 2010 | 05:10 AM
You could slather a big glob of bondo into it and then sand it down. However, that is the hillbilly way to do it. Mike's idea is much better.
Old Mar 3, 2010 | 07:01 AM
easytobedead's Avatar
Just A BaBy {:
hahaha well sad for my Hurst/olds....the person i got the car from slapped a big glob of bondo in the driver side rear quarter,didn't even bother to sand it down.....A Fix on my to do list which keeps growing .
Old Mar 3, 2010 | 04:22 PM
new user
thanks for the input i guess that is what i will have to do is get the patch panels....i want it to be right
Old Mar 4, 2010 | 10:49 AM
1964f-85's Avatar
I used the wheel lips from 71/72 front fenders to patch up my 72'. The driverside fender makes a near perfect wheel lip for the passenger side quarter panel. Looking at the photo and the fact that your in CA your little rust is what I would consider rust free here in Ohio. If its a small hole just fabricate a patch panel out of steel and but weld it in. I have relatives who built whole quarter panels out of maxwell house cans, pop rivets and bondo.... not a good idea!
Old Mar 4, 2010 | 11:55 PM
Bluevista's Avatar
Registered
Are we related?
Old Mar 18, 2010 | 10:20 AM
61F85Acid's Avatar
Bondo slathering is an art. I'm not a hillbilly, I'm just broke.
Old May 27, 2010 | 05:49 AM
geckonz08's Avatar
what I have done in areas where seams are involved .Cut out the rust entirely.then bend the metal inwards about 1/16 deep creating a lip 1/16 deep and 20 mm wide.The orig. metal is 1.5mm thick.I replace it and riveted it every 1" or so n the same time squeezing out the xcess sealant that was laid between the pieces.I cleaned off the excess sealant.The metal sheeting I used was i mm (galvanised ) and I bent a return on it at the edges to match the double lipped seam.This left a small 1/32 face difference which i bogged, primed
This is a budget fix but should be pretty permanent
mike
1973olds98
Jul 31, 2009 12:45 PM
easytobedead
Paint
Apr 10, 2009 06:16 PM
t_visker
Dec 29, 2006 08:59 PM
piano
Nov 14, 2006 05:03 AM
nosrevle
Mar 18, 2006 01:24 PM
