Molding fasteners
Old Nov 23, 2020 | 03:32 PM
scrappie's Avatar
Molding fasteners
Mocking up the vinyl top trim molding and forget how they were fastened at the spot with the hole? Should there be a hole drilled in the pot metal piece?
The rest of the trim is held on by the clips which use the stud and the front uses a screw. I dont recall what that was for? Was there another fastener with a stud that gets bolted from inside trunk?
Old Nov 23, 2020 | 04:05 PM
mrolds69's Avatar
Paul, it's been a long time since I worked in that area. I believe there is a clip with a stud that slides into the molding at the rear. The pot metal piece just slides into the molding, I think. I think you can see it in the"related thread" under this one. Joe P. posted a pic of the clip. There are different types and sizes, but something like that.
Old Nov 23, 2020 | 04:38 PM
RetroRanger's Avatar
72 Olds CS
is it like the button headed screw miles 71 just posted in his thread ?
see the last post
https://classicoldsmobile.com/forums...e-trim-150332/
Old Nov 23, 2020 | 04:46 PM
scrappie's Avatar
Thx Frank, Retro
Old Nov 23, 2020 | 04:52 PM
mrolds69's Avatar
Wow, that's a weird one! I don't think so, Dean. I think it's like one of those clips below this at the bottom of the Auveco chart. Not related topics but related thread underneath the topics. I don't know how to pull it up here.
Old Nov 23, 2020 | 06:34 PM
72 Olds CS
Yup I see it Frank i think your right
Old Nov 23, 2020 | 08:32 PM
mrolds69's Avatar
There you go, Paul! Good work Dean, Fusick sells those types of clips for Olds. Many different widths are available. It's something like the clips from one of those last 2 rows.
Old Nov 24, 2020 | 04:30 AM
scrappie's Avatar
Got it thx
Old Nov 24, 2020 | 07:36 AM
Miles71's Avatar
Here are a few more examples from my 1971 CS vinyl top trim mounting things.
Here is a sliding stud. These are used where you have access from the Trunk to add on a speed nut.
Some have studs welded to the trim. Usually found on corners and places with trunk access.
Here is a sliding mount. The screw goes into the roof.
In the picture above, the screw actually goes in the other direction
Old Nov 24, 2020 | 09:24 AM
My442's Avatar
Exclamation
The Fisher Body manual shows all of the clips and their locations.
Valuable book for reassembly.
Old Nov 25, 2020 | 06:29 AM
Miles71's Avatar
Hi MY442:
Not all Fisher body manuals are the same.
The one in the pictured below only contains a few items about mounting trim and only lists a fraction of the mounting devices .
I found it almost useless when I tried to identify my clips.
Which manual do you have?
scrappie
Sep 13, 2020 02:20 PM
scott_442
Aug 17, 2020 07:17 AM
cfair
Jul 2, 2019 12:11 PM
Fenian16
Jul 4, 2018 12:35 PM
wisniows
Jun 19, 2015 05:07 PM
