Finishing the underside of the body
Old Dec 11, 2020 | 10:45 AM
ajr2820's Avatar
Cleaning the underside up. I have to body on a rotisserie. Light surface rust only. Would you POR15 the bottom and top coat or use rubberized undercoating? Car won't see salt and will only see rain if I am caught out in it unexpectedly.
Old Dec 11, 2020 | 12:31 PM
Stefano's Avatar
"POR15 the bottom and then top coat" The POR will ahere best to a clean aged finish even with with light surface rust. The metal must have some bite, so a rough surface is best.
Old Dec 12, 2020 | 06:01 AM
chopolds's Avatar
I take no chances with my builds. Cars to be driven get POR-15 (or Master Series, which I like better) first, 2 coats 12 hrs apart. When the second coat is still slightly tacky, I put on rubberized undercoat, or better yet, bedliner. It's smoother, tougher, looks nicer, and doesn't absorb oil and grease, easy to clean. Use one that comes with a hardener, not a single component one.
72cutlass408
Paint
May 26, 2020 08:44 AM
Tlo154
Oct 5, 2014 03:18 PM
Boilerz25
Paint
16
Sep 18, 2014 11:01 PM
69goatpgh
Feb 5, 2012 07:26 PM
nukesec1
Sep 19, 2009 06:56 AM
