Mid-60’s Big Olds Fenders: J nuts or U nuts ?
Old May 18, 2022 | 09:53 AM
cfair's Avatar
Gang,
I’m chasing down some squeaks and groans in my front end (pretty much a permanent project). I’m wondering if I used the correct fasteners last time I put it all back together.
In my 66’s, there are quite a few 5/16”s -18 bolts securing the underside lip of the fender to the inner fender just above the wheels. I have J nuts in there now, with the “hook” of the J between the inner and outer fender. I’m not sure these nuts or installation is right.
If J nuts are what Olds used, should the “hook” of the J sit outside the lip of the outer fender and not between? It seems like putting the nut “hook” between the fenders allows for more movement than if you put the J hook outside and secured both fenders against each other.
Or did Olds use the longer U nuts and mine have just gotten replaced over the years?
I’m no body and fender guy, so please let me know what’s right here.
Thanks in advance
Chris
Old May 19, 2022 | 08:13 AM
nicks1966's Avatar
https://www.amkproducts.com/search-result/?ser=3784845
Old May 19, 2022 | 09:47 AM
cfair's Avatar
I looked at the same diagram yesterday. Many thanks for posting. My view is that Olds used J nuts, not U nuts, though either would work.
I also checked with my mechanic today, having the "hook" of the J between the fenders is not right.
The fenders should be fastened against each other with the J nut on the outside of both fenders, not in between.
Next few days somewhere I have some light body wrenching to do to fix this.
Chris
Old May 19, 2022 | 02:56 PM
The retaining tab for the Jnut will be between the 2 items being fastened.
MartinH
May 19, 2021 03:48 PM
JSPajak
Mar 13, 2017 09:02 AM
Nufo
Feb 15, 2013 10:30 PM
XTREMEGSXR
Jul 16, 2012 07:15 PM
sandman357
Dec 12, 2010 05:26 PM
