Interior Floor Pan and Rust treatment
Old Sep 19, 2011 | 07:44 PM
Steve Wike's Avatar
I finally got the seats out and "overall", the pan is pretty good, except on the front passenger side. Found rust was heavier here, one small pin hole, sanding with 80-100. Was next going to convert this section with OSPHO, several coats. Now, I really don't want to go the POR route at all, but what primer/treatment should I use after treating with OSPHO I guess I don't need to top coat with the "original" color, as no one will see it under the carpet. Oh, was thinking about cleaning out old pan joint sealer (front section by your feet-both sides). Most likely rust under here except at the high point (transmission). Thanks!
jstrits
Feb 7, 2016 11:33 AM
Freebeer
Sep 10, 2012 05:05 AM
HonestDave
Jun 6, 2012 06:49 AM
HonestDave
Mar 28, 2012 12:47 PM
yeahbuddy
Mar 27, 2012 06:35 AM
