How to fix screw holes on rear spoiler
Old Jan 12, 2014 | 05:26 PM
Johnd's Avatar
I picked up an original rear spoiler earlier today and overall it is in good shape with the exception of the screw holes on one side are stripped out. The center hole that holds the stud is fine, it is the two self tapping screw that are messed up. How hard is this to repair and what do you recommend. Thanks JD
Old Jan 12, 2014 | 05:42 PM
Professur's Avatar
screws into what? steel, pot metal, aluminium, fiberglass?
A load of JB weld or epoxy should fill the hole solid enough that you can drill a pilot hole.
Old Jan 13, 2014 | 05:47 AM
Johnd's Avatar
It is an original spoiler - so it would be fiberglass - it is where the pedestals meet the actual spoiler - the holes in the fiberglass are too big
Old Jan 13, 2014 | 07:03 AM
Professur's Avatar
Epoxy then. Pretty much any filler will work. A quick fix would be to head to your local marina. Glass repair kits are an over the counter item for them.
Old Jan 13, 2014 | 08:08 AM
69442C's Avatar
If you are not worried about the fasteners being 100% correct, I would expoy threaded studs into the spoiler holes and then use washers and nuts to hold it to the deck lid.
garry442
Aug 22, 2015 11:42 AM
auto_editor
Jul 9, 2015 07:34 AM
Oldracerjones
Mar 3, 2014 07:38 PM
Lady72nRob71
Brakes/Hydraulic Systems
Oct 7, 2011 08:19 AM
#1CutlassSupreme
Nov 20, 2008 09:04 AM
