Floor Pans completed
Old Aug 25, 2009 | 10:18 PM
1973olds98's Avatar
I recently stipped out the interior on my 1973 olds 98 to find some rust spots that needed some attension..One section was under the passenger front seat..The other was to the left of the brake pedal..It was a pretty easy fix..I traced the shape i need out on some carboard and then drew the pattern on some sheetmetal and then cut out the rusted section and weld in the new...I then used a anglegrinder to clean off most of the surface rust that was on the other parts of the floor....I then coatd the areas down with naval jelly...After all of this I was pretty much looking at a rustless floor....I cleaned wverything up with purple power degreaser and dryed everything and used some truck bedliner coating and put 2 thick coats on the entiire floor..It came out awesome,,,,
Old Aug 25, 2009 | 10:21 PM
1973olds98's Avatar
hi
Old Aug 25, 2009 | 10:32 PM
1973olds98's Avatar
hi
Old Aug 26, 2009 | 04:08 AM
scrappie's Avatar
Good for you, looks like a solid repair.
Old Aug 26, 2009 | 04:35 AM
nice wrok
Nice job
what's next?
Old Aug 26, 2009 | 05:52 AM
BLUE72RAGTOP's Avatar
very nice! What truck liner stuff did you use?
Old Aug 26, 2009 | 06:50 AM
1973olds98's Avatar
rustoleum truckbedliner coating from walmart....43.00 a gallon......i was going to use pro-15 but funds wouldnt allow it..I know several people that has used truckliner stuff to seal repaired metal and it works real good..My next job unfortunely is trying to figure out my choke,,,,
Old Aug 26, 2009 | 05:12 PM
1973olds98's Avatar
I am going to get her on a lift and begin cleaning of the old undercoating off the bottom...Most is peeling off easily..I will sand the heck out of everything...Apply several coatings of eastwood rust convertor,,,And then spray everything with new undercoating spray....I hope my works keeps the old car together a few extra years
nonhog
Jan 1, 2019 08:17 PM
jon1957
Body work
16
Nov 2, 2018 09:10 PM
CaliBigBlock
Mar 23, 2012 11:17 AM
1973olds98
May 14, 2010 07:58 PM
J'ville
Aug 19, 2006 01:07 PM
