Easier way to remove windshield sealer????
Old Jun 26, 2013 | 08:03 AM
dub dub's Avatar
I hope I'm posting this in the proper section, (fairly new here), but i just removed my cracked windshield on my 70 cutlass and I was wondering if there is a "MAGICAL" solution for removing all the old sealer, other than screw drivers and putty knives??? I'm also prepping for paint in the near future so I figured i better get it nice and clean. Thanks
Old Jun 26, 2013 | 12:12 PM
m371961's Avatar
Heat gun
Old Jun 26, 2013 | 01:45 PM
Heavy plastic scraper, rags and WD40.
Old Jun 26, 2013 | 04:21 PM
coppercutlass's Avatar
Chevy budget Olds powered
Buy some razor blades and slide it across the edge at a 160 ish degree angle like a putty knife but since the razor blade is sharper it will cut it faster you gotta be careful. If you have a 3 in. grinder use one of the scotch brite roloc pads/ cookie looking buiscuit wheels and that will work great just tape off the trim and tape some plastic over the gaping hole so no crap gets inside. Also you can use your putty knife and heat it up with a propane torch. map gas. and that will also do the trick pretty good.
Old Jun 26, 2013 | 05:26 PM
oldstata's Avatar
Justin
Piano wire lol I ve done a few
Sorry only read half the post my kids were talking to me lol
Yeah razor blade heat gun all work great
Old Jun 26, 2013 | 08:19 PM
Lady72nRob71's Avatar
Plastic or wood scraping tools. Can be made from popsicle sticks or old CDs cut up. Both worked for me. They remove the sealer without tearing up any painted surfaces much.
Old Jun 26, 2013 | 08:36 PM
ihengineer76's Avatar
Once you get the most of it off, WD-40 works wonders, as Oldcutlass said. You may want to soak the seal for a little while with some WD before you try and scape it off. It softens the stuff after setting up rock hard from 40+ years of sun!
Old Jun 26, 2013 | 08:39 PM
If you used WD40, make sure you remove all the residue with naphtha or similar so that the new sealer will stick correctly.
Old Jun 27, 2013 | 04:47 AM
dub dub's Avatar
Thanks for all the tips, i will be trying them this weekend. BTW, the sealant is still real gummy, its like trying to remove a ton of bubble gum, so I'm assuming the wd40 is mainly just for clean up after I've scraped most of it off?
Old Jun 27, 2013 | 06:20 AM
Yes remove the bulk of it and then you can remove the thin layer that remains with the WD40. It's good for removing tar splatter and road grime also.
Old Jun 27, 2013 | 06:08 PM
Try paint thinner to dissolve it.
Old Jun 27, 2013 | 06:36 PM
Also wax and grease remover will work. They sell it at autozone.
therobski
Body work
Mar 3, 2015 07:15 AM
RockAuto
Jan 23, 2013 12:14 PM
ATrain1
Non-Olds Engines
Jun 29, 2012 12:58 PM
344870M
Aug 21, 2009 08:04 AM
TOONLOVESCHERYL
Drivetrain/Differentials
Nov 18, 2006 02:12 PM
