Door Latch Pin Question
Old Aug 27, 2024 | 12:49 PM
radiofellow50's Avatar
SO, if I remove the door latch pin on my 75 Olds Cutlass, will the nut in the frame drop out and i have to go fishing for it or is there a retainer back there for re-insertion of the pin? I have to remove it to put a nylon bushing on it! I don't want this to end up like some of my other "quickie" projects.....you know, only a 5 minute job that takes 2 hours!
Old Aug 27, 2024 | 01:11 PM
Tuffnut's Avatar
It won’t fall out. It may drop slightly as they are adjustable. Put a pencil mark around the washer so you can put it back in the approx location.
Old Aug 27, 2024 | 02:22 PM
Thank you. Appreciate reply.
Old Aug 28, 2024 | 12:47 PM
Just to expand on the description a little, the "nuts" in the cavities are called floating nutplates. There's a plate with the threaded hole that acts as the nut that is captured in a sheet metal cage that holds it in place but allows it to float a little for adjustment and to accommodate tolerance stackup. This same feature is used on the plates that the door hinge bolts thread into.
Old Aug 28, 2024 | 01:35 PM
Thanks, that's what I was wondering.
carnutz
Nov 16, 2022 07:38 AM
scrappie
Feb 17, 2021 06:04 PM
Arrowstorm
Body work
Jan 22, 2016 12:48 PM
Sampson
Apr 25, 2014 04:45 PM
starfire
Mar 12, 2013 06:58 AM
