Don’t want to replace vinyl top 68 Cutlass S
Old Mar 9, 2019 | 09:06 PM
jurrasicpork's Avatar
Hey guys,
Had my roof replaced a couple years back and after that fustercluck of a job I have no desire to put new vinyl up there so I’ll be painting it all one color. Obviously now I have gaps where the vinyl once was. Do I have to remove the trim, grind everything down & fill the gaps in? At a loss as what to do here. I’m sure this has been asked before but not recently that I can see. Any advice is greatly appreciated!
—Mango
Old Mar 11, 2019 | 05:18 AM
JohnnyBs68S's Avatar
I think all you need to do is to remove all trim that separated the vinyl from the paint, grind-down the studs that fastened them, smooth whats left w/ mud and paint. I think this is basically just the trim behind the rear window that wraps across the trunk lid.
Old Mar 11, 2019 | 08:19 AM
There are a few fastener holes that need to be welded up - one at either end of the trunk trim and a couple on each side on the quarter panel. The weld studs are easy to grind off.
Old Mar 11, 2019 | 08:33 AM
IDK why you wouldn't just make it into a two tone (paint) car and leave the trim alone.
Old Mar 12, 2019 | 10:50 AM
The rear trim was removed when the roof was replaced. No studs to attach the trim to anymore.
Old Mar 12, 2019 | 11:05 AM
green1972's Avatar
not sure if its auveco or ? but the little t studs are available aftermarket and the have a small thread on them you turn in with a phllips to attach the plastic clips that go in the trim pieces, or actually snap in to the trim pieces
Old Mar 12, 2019 | 11:29 AM
What "gaps where the vinyl once was" are you referring to then? Do you mean "pits" in the roof, A- and C-pillar metal underneath where the vinyl was once glued? If so, then yes, that needs to be sanded and smoothed with body filler. I don't think you need to remove any chrome trim from the drip rails to do that though.
Or are you referring to gaps in the drip-rail chrome trim where the vinyl was once tucked-under? If so, that's a good question. I think that it would just be a matter of crimping the trim tighter on the drip rails to close that gap. I've never removed the drip rail chrome trim, so I don't know how hard that is to do (or if it is even advisable).
Old Mar 14, 2019 | 10:48 PM
sorry, referring to the gaps in the drip rail. It’s got a fair amount of rust. I’m worried that crimping it would end up trapping moisture and ruining the new roof down the road. No way in hell am I replacing that again!
Old Mar 15, 2019 | 06:38 PM
Yellowstatue's Avatar
There used to be a kit to use with a wrinkle painted roof that included tape to make it look like a vinyl roof. No problem with rust after that.
Wachterl442
Jul 31, 2019 06:05 PM
sgolds
Jul 2, 2019 02:48 PM
hooterville cutlass
Feb 27, 2016 08:15 AM
mcalvo
Jun 12, 2014 07:17 AM
72hurstpilot
Jun 24, 2011 10:15 AM
