73 cutlass supreme vinyl top trim
Old Oct 5, 2015 | 06:25 PM
hooterville cutlass's Avatar
Hi looking for a good set of trim for a full vinyl top. I need the ones that go under the rear window and down each side under the rear side windows. If anyone has all or part of this trim please let me know. I just need the piece that bolts to the left rear quarter and goes under the formal window. Thank you David
Old Oct 27, 2015 | 07:04 PM
Hi still looking for vinyl top trim
Please let me know if anyone has the trim
Thanks David
Old Nov 13, 2015 | 02:00 AM
Still looking for trim
Old Feb 8, 2016 | 05:59 PM
Wink
Still looking for the vinyl top trim
Hoping someone can help me out
David
Old Feb 8, 2016 | 06:24 PM
2blu442's Avatar
David, I think I've got these. Please send me a reminder Saturday and I'll try to locate them.
John
Old Feb 8, 2016 | 06:52 PM
Ok I will send a reminder Saturday morning
Thank you for getting in touch with me
David
Old Feb 8, 2016 | 11:49 PM
allykatt 1992's Avatar
I have a real descent set off a 76-77 . I'm thinking theirs a difference from the 73 and 74-77 .
Old Feb 9, 2016 | 03:47 AM
allykatt
you are right the trim around the bottom and the quarter windows is the same for 1973 thru 75
the rear window trim is also different on my 73 cutlass supreme the side trim is longer at the bottom it is about 2 1/2 inches longer on each side making the center piece shorter. on 76-77 the side pieces are shorter.
thanks David
Old Feb 19, 2016 | 03:52 PM
Still looking for the vinyl top trim for my 73 cutlass supreme it has a full vinyl top
If anyone has the trim please let me know.
I also need the clips that hold the right rear quarter window and the rubber spacers thar the quarter window sits on
Thanks David
Old Feb 20, 2016 | 03:59 PM
2blu442's Avatar
Hello David
Well, I've got a pile of trim that is aluminum and has the correct pattern for 1973-74 but I can't say for sure what each piece came off of. Once again, I'm kicking myself for not writing on the back what I pulled them from. There's one short clip that is a clear V pattern, likely the top of back windshield on a Supreme. If you would look at the pictures and if there's anything that looks like it might be what you need let me know which ones they are and I can take measurements for you. John
Then these pieces are smooth with no pattern on them. Two badly bent ones that are L shaped. Then one that looks like it may have gone over the roof for the half vinyl top.
Old Feb 23, 2016 | 05:49 PM
Hi John
Not quite the trim that I am looking for
Thank you for looking and letting me know
Thanks again David
Old Feb 27, 2016 | 08:15 AM
Still looking for the trim I need the trim that is painted and has the grain in it like the vinyl top has. If abyone has this trim please let me know.
Thanks David
70Post
Mar 29, 2026 01:12 PM
Oldssupreme
May 28, 2013 05:35 PM
slater442w30
Feb 20, 2013 03:59 PM
hinz57
Aug 10, 2010 08:16 PM
jdeeere
Aug 6, 2010 05:17 AM
