Body sealer (for a/c heater box to firewall) vs butyl rubber for rear window
Old Apr 8, 2018 | 07:05 PM
Oldssupreme's Avatar
Chris
https://m.ebay.com/itm/AMK-Products-...pid=1833199116 Hello. I am planning on using this product to seal my a/c heater blower to the firewall on my 72 cutlass. Can I also use this to set and seal my rear window or should I use butyl rubber?
Thank you!
Old Apr 8, 2018 | 07:27 PM
coppercutlass's Avatar
Chevy budget Olds powered
Use the butyl for the heater box but for windows go modern and use window urethane .
http://www.tptools.com/Pro-Form-Buty...Tape,3408.html
Old Apr 9, 2018 | 09:27 AM
oddball's Avatar
For the heater box, and similar items, just use rope caulk from your local big box hardware store. That's all those guys are selling - that's not butyl, but with a healthy markup.
Old Apr 9, 2018 | 09:28 AM
oddball's Avatar
Butyl is a real pain to clean up, so I wouldn't use it except where necessary. Which with urethane for windows, there's nowhere that butyl is necessary.
Old Apr 9, 2018 | 09:41 AM
Fresh butyl cleans easy with mineral spirits. Old butyl will flake off in chunks as it hardens up over time. I would not use urethane on the box as you usually have to cut it. Its very very permanent so for glass its perfect as you can cut it out but for hard tp reach spots it will suck
Old Apr 9, 2018 | 11:19 AM
Chris
https://m.ebay.com/itm/Caulk-Wthrstr...MAAOSwjL5ZMYGV thank you for the replies. Some of you said rope caulk. Do you mean this stuff? Am I looking for a putty type material or a foam type material?
Old Apr 9, 2018 | 06:57 PM
classicmuscle442's Avatar
Yes that the caulk but lowes and Home Depot sell it.
Platinum69
Oct 28, 2017 07:08 PM
c-towndave
May 3, 2015 07:55 PM
Skitch72
Jul 2, 2014 06:06 PM
rn_mccy
May 28, 2012 05:08 PM
xx69442
Jan 14, 2010 03:07 PM
