Removing lower radiator brackets 72 Cutlass
Old Apr 7, 2018 | 03:14 PM
csouth's Avatar
I need to remove my lower radiator support brackets from my core support as my aftermarket radiator is too wide. Before I go crawling under the car, are these spot welded to the core support?
Old Apr 7, 2018 | 04:46 PM
Yes, they are welded.
Old Apr 7, 2018 | 05:41 PM
oddball's Avatar
Cheap and cheery alternative (which I've done several times now...): Bash the #@%@#%$ out of the back half of the bracket to flatten it. Done!
Old Apr 8, 2018 | 06:57 AM
cdrod's Avatar
Rodney
Chris:
Use a spot weld cutter bit (see pic below) to remove the old radiator saddles, then buy the larger replacements from Fusick or another Olds vendor. You can plug weld the new ones in with a MIG welder.
Rodney
Old Apr 8, 2018 | 09:52 AM
Yellowstatue's Avatar
'67-'70 Toro lower rad brackets are bolt in . One bolt. L391319 & R391318.
Last edited by Yellowstatue; Apr 8, 2018 at 10:34 AM. Reason: The 'BOOK' is just chock full of stuff!
Old Apr 9, 2018 | 10:45 AM
csouth's Avatar
Originally Posted by cdrod
Chris:
Rodney
Thanks,
I'll get on that this week.
Old Apr 9, 2018 | 01:34 PM
Yep, I did that back in the 80s when I put a 4 core radiator from my brother-in-law's '68 GTO into the Cutlass. I was able to bend them back out when I had the original 3 row radiator recored.
Old Apr 10, 2018 | 07:42 AM
oddball's Avatar
Yeah, my work is always a little bit Kindigit, and a little bit Roadkill.
gtuturbo
Mar 31, 2017 04:13 AM
olddaz
Aug 27, 2014 06:39 PM
bobfo1
Jun 13, 2013 01:24 PM
w-30dreamin
Nov 24, 2011 09:11 AM
RATCHETMASTER
Brakes/Hydraulic Systems
Jan 29, 2009 07:45 AM
