70 442 Hood
Old Sep 25, 2019 | 01:41 PM
2oldsguy's Avatar
70 442 Hood
My 442 has an original fiberglass hood and I could never get the left rear corner down to the fender since I have owned the car.
Is this common and is there a solution.
I tried to adjust the hinge, elongated the holes and still no good.
The right side is perfect.
Thanks,
Joe
Old Sep 25, 2019 | 03:47 PM
Is there any interference? Try raising the rear of the hinge.
Old Sep 25, 2019 | 04:26 PM
svnt442's Avatar
I think this has to do with the hinge being worn out, and no amount of adjusting will fix the problem because of that. You either need to replace it with a good hinge, or have that one repaired.
Old Sep 25, 2019 | 06:52 PM
2oldsguy's Avatar
As far as I can tell there is no interference and I will try raising the rear of the hinge.
If what oldcutlass suggestions do not pan out I will remove the hinge and check it out.
Thanks,
Joe
boese1978
Body work
Jun 18, 2017 06:33 PM
woodie582
Body work
26
Mar 29, 2016 05:27 PM
73aussie455
Nov 25, 2014 06:59 PM
ah64pilot
May 11, 2011 04:32 AM
