68-69 Repro front fenders
Old Jun 7, 2018 | 07:28 PM
yorkman's Avatar
There appears to be two different reproduction front fenders for 68-69 Cutlass now. The original Goodmark repro fenders are now available for about $415 each on line, but the newer repros are priced much higher at $565 each. Does anyone know why? Is there a significant difference?
2nd question; will a 68 cutlass hood work on 69 hinges on 69 fenders with a 68 core support?
Thanks.
Old Jun 8, 2018 | 08:52 AM
allyolds68's Avatar
Thanks.
A 68 hood will work with 69 hinges if you modify the hinge holes by elongating them about 1/4". There isn't any issue with using 69 fenders on a 68 core support.
I'd be surprised if there were two different manufacturers making 68-69 fenders but I wouldn't be surprised that someone is trying to sell them for a lot more
Old Jun 8, 2018 | 11:43 AM
I would tend to agree, however there are now second sources of some of the Olds repro panels, and frequently these use better dies and thicker metal that is closer to factory. I first found this out when I bought front fender patch panels from Autobody Specialties. Their 70-72 patch panels are much better than the ones originally available. Unfortunately, I do not know if this also applies to the front fenders in this thread.
Old Jun 8, 2018 | 03:23 PM
Brad J.'s Avatar
I fitted a set of goodmarks to a 68' last summer. They seemed as heavy as the originals but I had to shape them from the middle of the door to the top. Probably welded and shaped from 0 to 1/4" at the top.
This was to make them fit nice. And the originals didn't fit that nice either.
The lines down the hood were crisp as is.
69wmachine
Body work
Jun 2, 2023 02:52 AM
rcorrigan5
Feb 12, 2017 05:21 PM
Bernhard
Jan 3, 2017 12:11 PM
perchhead
Body work
Mar 17, 2013 04:54 AM
62radarlove
Body work
Jan 22, 2012 11:52 AM
