67 Cutlass 442 Front Fender Extension "Gasket"
Old April 7th, 2022, 11:40 AM
mwbailey's Avatar
OK, so I discovered that 1966 front fender extensions do not fit with the 1967 body. . . the hard way. Made an emergency trip to Richard's Salvage to keep the body shop working. Removed three front fender extensions (with the chrome "eye brow") and found pieces of cardboard in two of them. I have the cardboard "gaskets" to replace, but body guy says anything that comes close to "showing" will get feathered with final buffing.
The questions then are, should we use the cardboard or just leave it out? Are the extensions painted on or off the car? What did the factory do? If painted separately, do you then paint the edge of the "gasket" before installing?
Oh, and fortunately, two of the three extensions will make a proper pair. . . .
Thanks for advice!
mwbailey is offline
Old April 7th, 2022, 11:52 AM
Oldsmaniac's Avatar
I believe the factory painted the caps then bolted them on after the fender was painted. All gaskets I have seen did not have a color on them/overspray. They were there most likely to avoid a squeak and possible rubbing from vibration that could cause paint loss and rust eventually. They tend to sit back from the fender edge so a buffer would tend to miss them.
Oldsmaniac is offline
Old April 7th, 2022, 02:12 PM
^^^THIS! If the body shop thinks they get installed prior to painting, find a new paint shop.
joe_padavano is offline
Old April 7th, 2022, 06:57 PM
mwbailey's Avatar
Thanks, Maniac, we had pretty much come to that conclusion, but confirmation is much appreciated. I'm afraid that we're too far along for a new body shop, Joe. But he had recommended painting separately and I wasn't sure. I think we're good, but I like hearing from the experts.
mwbailey is offline
70vista
January 15th, 2020 08:34 AM
Alaska442
September 10th, 2019 02:12 AM
442iowa
June 4th, 2013 04:52 AM
project67
July 23rd, 2012 11:44 AM
Quick Reply: 67 Cutlass 442 Front Fender Extension "Gasket"
