55 88 Door and fender alignmentt
Old Sep 26, 2015 | 12:16 PM
jozw30's Avatar
OK, spent better part of a day already, and I get them close, then try to make a samll final adjustmetn and seem to go back to square 1.
Can someone with good sedan (post) door post a picture of the area where the top rear of the fenders meet up with the cowl, windshield molding and upper window frame portion of the door?
I typically enjoy this type of challenge, but I'm losing patience and figured I'd see if there was a trick to this.....
Doors are orginal to the car and they fit pretty nice when I took it apart.
Fenders are rust free replacements I found.
I have everything in epoxy and two coats of high build.
I wanted to do a final mock up to see if there is any filling needed across gaps and I planned to drill the hinges for later when I get to final assembly.
Old Sep 27, 2015 | 09:58 PM
Ozzie's Avatar
Here is the passenger side of a 1955 88 four door sedan. This is the way the factory in Lansing put it. None of the components in the photos have ever been removed or adjusted. The driver's side is similar. I apologize for the sad lighting. Those shop lights aren't very good for photography.
Old Sep 28, 2015 | 05:03 AM
jozw30's Avatar
Thanks Ozzie! This helps a lot.
So along the window stainless, the door frame is almost flush or is it recessed slightly?
Doing some research, it looks like I will have to play with the body mount shims a little and that might help as well. I just put the body back onto the chassis.
Appreciate the help!
Old Sep 28, 2015 | 06:06 AM
Ozzie's Avatar
I am having a bit of trouble understanding exactly what the question is. Can you say it another way? Is the "window stainless" referring to the vent shades? The door is recessed when compared to the drip rail.
Old Sep 28, 2015 | 06:16 AM
jozw30's Avatar
Does this help?
Old Sep 28, 2015 | 07:12 AM
Ozzie's Avatar
Does this help?
Yes that helps a lot. It's like the guy said, "A picture is worth a thousand words".
On the one I have, the door is slightly recessed and varies a bit from top to bottom of the windshield's stainless. At the top and at the bottom of the stainless, the recess is approximately 1/8"; at mid height of the stainless, the recess is about 1/16".
Old Sep 28, 2015 | 07:27 AM
jozw30's Avatar
That's great Ozzie, that's what I needed!
I'll shoot for slightly recessed on the molding.
Thanks again for taking the time!!
Joe
Old Sep 28, 2015 | 03:43 PM
Rocketowner's Avatar
Ozzie,thanks for stepping up with the photos he needed.I sent him the name of another member that had an original '55 Sedan, but I knew someone would be willing to help. Larry
rfmoody
Jan 20, 2015 03:31 AM
Nufo
Feb 15, 2013 10:30 PM
67 Olds 442
Mar 21, 2012 08:21 AM
Olds24
Feb 21, 2012 10:52 AM
ddx77
Jun 24, 2010 10:49 PM
