1972 Cutlass Supreme eyebrow trim question...
Old Sep 7, 2018 | 08:40 AM
72455's Avatar
1972 U code Supreme
Trying to replace the eyebrow trim on the passenger side, and it seems like there are no nuts on the studs that hold the trim in place. I've spent the last hour trying to get a socket on them, and I've tried every small size I have from 3/16 to 5/16 and they're either too big or too small. The only size I didn't have was 7/32...is that what I need, or am I overlooking something?
Thanks,
Dave
Old Sep 7, 2018 | 08:48 AM
Time to get one of these from Harbor Freight...
Actually, have you tried snapping a photo with your cell phone camera?
Old Sep 7, 2018 | 09:06 AM
72455's Avatar
1972 U code Supreme
This is what it looks like...
Old Sep 7, 2018 | 09:26 AM
Well, clearly there are no fasteners on those posts. Even with the nuts removed, I've had the cut threads on the posts catch on the edges of the holes and the piece acts like it is still held on somehow. Unless it was glued in place, you will have to resort to brute force. I use a rod and small hammer to tap on the ends of the posts to work it loose. A piece of wood also works.
Old Sep 7, 2018 | 09:29 AM
72455's Avatar
1972 U code Supreme
Will give that a shot and thanks for the advice Joe😀
Old Sep 7, 2018 | 09:58 AM
72455's Avatar
1972 U code Supreme
Worked like a champ Joe! Thanks again!
Old Sep 8, 2018 | 06:05 PM
72455's Avatar
1972 U code Supreme
What's the easiest way to get the speed nuts onto the posts without dropping them? I tried for an hour last night but the space is so tight, I got nowhere.
Thanks,
Dave
Old Sep 8, 2018 | 06:32 PM
Thanks,
Dave
I use a deep six point socket and a long extension. Stick the nut into the socket using tape or thick grease or some sort of stickem.
Old Sep 8, 2018 | 06:42 PM
72455's Avatar
1972 U code Supreme
1/4 or 3/8 drive?
Old Sep 8, 2018 | 07:01 PM
442crzy's Avatar
1/4 drive easiest
Old Sep 8, 2018 | 07:31 PM
1/4 or 3/8 drive?
I doubt it really matters. I've always used a 3/8s there.
coppercutlass
Mar 15, 2018 07:00 PM
Bitburger
Body work
May 20, 2016 04:46 AM
LoganMiller68
Body work
May 15, 2014 07:20 AM
Colorado Olds
Dec 28, 2008 10:09 PM
