1955 Olds - Sagging Hood Springs
Old October 5th, 2010, 05:46 PM
Collector of Stray 55's
Olds Dad's Avatar
I'm restoring a 55 with weak hood springs causing the hood to sag - any insights to fixing this? Can these be replaced - where do I get replacements? Thanks in advance!!
Olds Dad is offline
Old October 14th, 2010, 12:29 PM
442Harv's Avatar
Did you try Fusick?
442Harv is offline
Old October 14th, 2010, 12:52 PM
Registered
Bluevista's Avatar
If it's the same spring as a '55 Chevrolet you can get them at any Chebbylay place.
http://www.classicchevy.com/chevy-ho...l?dept_id=1457
Bluevista is offline
Old October 15th, 2010, 11:50 AM
bjtstarfire's Avatar
I am curious about this also for a 61 Olds. My question would be: If the dimensions are the same how would you determine if the spring load is right to hold your hood vs. the load for the one being sold.
Perhaps it is a non issue but I am not sure.
bjtstarfire is offline
Switch Blade Betties
March 22nd, 2013 12:42 AM
projectheaven
Suspension & Handling
January 4th, 2012 09:32 PM
dallasite21
August 18th, 2009 12:57 PM
case2273
July 16th, 2009 02:02 PM
pakrat
Body work
July 11th, 2009 10:20 PM
Quick Reply: 1955 Olds - Sagging Hood Springs
