Square Nuts for inner fender & hood hinges and radiator support
Old March 8th, 2013, 01:02 PM
wmlewis's Avatar
Square Nuts for inner fender, hood hinges & radiator support 66 Olds 442 & others
If you are looking for the inner fender nuts that are used on 66 Olds Cutlass/442 that are pressed in when the fender and other parts are stamped out, I finally found a source...
They are called 5/16" Pierce nuts...
The supplier is AMK products website WWW.AMKPRODUCTS.COM
The part number is B-10558 sells 6 nuts for $4... minimum order is
$30 plus shipping....
AMK is an automotive fastener supplier for low quantity items, I will be using their
415 page catalog quite a bit. You will receive the catalog on your first order.
Please respond to me if you found this helpful... Bill Lewis
wmlewis is offline
Old March 8th, 2013, 08:18 PM
Lance
ROCKET VAPOR's Avatar
AMK provides a great service. I have gave them a lot of business over the years. Good, polite people too.
ROCKET VAPOR is offline
Old March 8th, 2013, 08:25 PM
There are ususally Fastener or Bolt stores located in most cities. Auveco also carries a wide variaty of specialty fasteners and the bolt stores may have these items in stock where you won't have to meet the $30 minimum + freight.
oldcutlass is online now
Old March 8th, 2013, 09:05 PM
wmlewis's Avatar
I went to Fastenal and they use the Auveco catalog and could not find these pierce nuts in their catalog...
wmlewis is offline
Old March 9th, 2013, 07:24 AM
Fastenal, well ... some of their stores are ok. The one here sux.
Old January 13th, 2014, 10:08 AM
DLaz70OLDS98's Avatar
Bill I found this very helpfull as I was looking all over for these pierce nuts! Thank you for posting this great resource!!!!
Drew
DLaz70OLDS98 is offline
Old January 13th, 2014, 09:49 PM
wmlewis's Avatar
You are welcome.... Hopefully others will find it useful also... Bill
wmlewis is offline
Tom442
August 26th, 2012 05:20 PM
RandyS
July 7th, 2012 09:58 PM
dsolomon
April 10th, 2012 05:36 AM
NastyNate6695
January 2nd, 2012 09:40 AM
georgiaboy697
July 2nd, 2010 09:23 PM
Quick Reply: Square Nuts for inner fender & hood hinges and radiator support
