Need '66 442 trunk drop off panel (s)
I'm in the process of replacing the trunk floor and after pulling out the old floor I found some poor body work replacing the right rear quarter panel. The
trunk floor to the quarter is rusted badly and can't even be used for a pattern to make a new one.
All the parts houses start with the '68 and newer for those panels and I've checked about a dozen, has anyone run across them?
I would prefer to get a new replacement panel but if anyone has a real decent used panel, I would be interested in that also. Bill
Goodmark lists their drop offs for 66-67 Chevelles as also fitting the 66-67 Cutlass. Don't buy them, I did and they do not fit. The pattern is similar but about 3" too short. I haven't been able to find them any where.
I love the 66/67 and wish I still had one.
If it's true that the 66/67 Chevelles also fit and you're looking for other than Goodmark, I found this on a search. Is it what you need?
If it looks like the right part, here's the website I got it from. http://www.parts123.com/0000080d/A74...er-a743500.htm
Not that expensive either if it's right. Good luck, hope you find the part you need.
Hmm, that link didn't work like I thought it would. Try this one: http://www.parts123.com/parts123/yb....ort~1~cadeflbd
I have a right corner from the wheel back. I cut the quarter and through the trunk floor. It was intended to fix a car that had lost a rear wheel and trashed the quarter, but the guy ended up repairing what he had. Here it is with a hood leaning on it:
Amazingly it started raining here in So. Nev. just before I got to it, so you can see rain drops in the desert dust of the underneath side. Be aware that I am going to New Mexico tomorrow. You can continue contacting me via PM.
Run to Rund what are you asking for the piece?
