Help! 1970 W-30 OEM Gold Stripes Paint
Old May 14, 2024 | 01:41 AM
w30brad's Avatar
Help! 1970 442 W-30 OEM Gold Stripes Paint
Can anyone help with color match info for 1970 442 W-30 Gold Stripes? Years ago, my stripes were sprayed the incorrect color (Nugget Gold) and I want to make it right.
I know this much:
  • The PPG color code is: 23197. PPG no longer has the mix formula.
  • The WSA Code is 3918
  • The DuPont number is 898-99617. DuPont no longer has the mix formula.
A spray card sample or color mix formula info would be greatly appreciated.
I want to get as close as possible to the correct color.
Thank you in advance
Old May 14, 2024 | 01:59 AM
TCP Global can mix to those formulas in lacquer, urethane, or BC/CC.
Old May 14, 2024 | 05:21 AM
69HO43's Avatar
for Chevrolet GOLD WSA3918 Single Stage | eBay
They sell it in spray cans, so SOMEONE must have the formulation. However, no idea about quality or color match. Maybe contact them about getting a mix formulation for a pint to do the stripes?
Old May 14, 2024 | 09:32 PM
w30brad's Avatar
Thanks Joe, I'm going to contact TCP
Old May 14, 2024 | 09:33 PM
w30brad's Avatar
Thanks 69HO43, I ordered a can today to see how it looks
Old May 18, 2024 | 09:03 PM
w30brad's Avatar
Oh for two now.
1) I ordered a spray can of GOLD WSA3918 base coat from Color My Auto (on Walmart website). Not even close. It’s not even gold in color, much less the 1970 Oldsmobile WSA3918 Gold Stripe color.
2) I ordered a spray can of GOLD WSA3918 from Paint My Ride (on ebay). Color is not close, but at least it’s gold. It’s a metallic paint, so that’s wrong too. I think all 1970 Oldsmobile stripes were non-metallic paint. I know for sure that the Gold was a non-metallic
On Monday I’m going to give TCP Global a try. If that doesn’t work out, then I’m back to square one.
Here’s a spray out of the Color My Auto GOLD WSA3918 I ordered:
Here’s a spray out of the Paint My Ride GOLD WSA3918 I ordered:
Hopefully someone here has an original 1970 Gold stripe car with matching paint formula and can help me out.
Old May 19, 2024 | 05:31 AM
Stripes were not metallic.
Old May 19, 2024 | 06:29 AM
Hairy Olds's Avatar
Shoveling Snow
The color is more of a tan.
Old May 19, 2024 | 09:57 PM
w30brad's Avatar
Yes, it'd definitely a tannish gold. Do you happen to have original an gold stripe color match sample or paint mix info? Thanks
Old May 20, 2024 | 04:10 AM
69HO43's Avatar
What ever happened to those paint scanner things that some of the higher end paint supply shops had where you could have them scan the paint and it spits out a formula for matching the color? If someone had a car with original stripes, it's a possibility. I had them do it to some H/O gold on an original paint trunklid and it didn't turn out too terrible. The only issue is it will take into account for weathering and fading, etc., so it may not be a super-exact match to factory.
Old May 20, 2024 | 05:30 PM
w30brad's Avatar
I would like to do it that way, but I don't know anyone who has an original (or correctly repainted) gold stripe car. If anyone knows someone who knows someone...
Old May 28, 2024 | 03:15 PM
w30brad's Avatar
I heard back from TCP Global today and they do not have a formula available to mix the 1970 Oldsmobile gold stripe paint. My search is now back to the starting line.
I think my only options are to find someone here who:
  • has the paint mix formula
  • will let me borrow a paint swatch / sprayout card so I can get a match made
  • has a correct gold stripe car and is willing to take their car to their local paint dealer to get a color scan
  • has a correct gold stripe car and is planning on attending a car show in 2024 within 300 miles of Reno, NV so I can bring color swatches to match
Anyone here in Olds land who can lend me a hand?
Old May 28, 2024 | 05:15 PM
70Post's Avatar
I'm "digging around" here.....don't know if I'll be able to come up w/anything but I have feelers out.
Old May 28, 2024 | 05:43 PM
OLDSter Ralph's Avatar
Go to a paint supplier that knows whats going on. Working on a PPG page to post. PPG code G, H. #23197
Let me work on the scanner and post a page later. File is to large right now.
Old May 28, 2024 | 08:13 PM
w30brad's Avatar
Go to a paint supplier that knows whats going on. Working on a PPG page to post. PPG code G, M. #23197
Thanks Ralph, I've been the PPG route in depth. I've contacted PPG suppliers and corporate. PPG no longer has a formula for the 23197 Gold. They said it's an old lacquer paint formula and they don't have a matching cross reference in their paint line. They have one that's listed as 'a close match' and I had them mix me a pint and I did a spray out. It's very similar, but it's too dark.
Old May 28, 2024 | 08:29 PM
70Post's Avatar
"Very similar" to what??? Do you already have a known accurate/correct sample to compare the sprayout card to?
Do you have a talented painter/pain mixer there?? Someone who really knows how to mix and tweak colors?
If you have a formula that is "close" it seems like a talented painter could look at the color, the tints used, volumes, etc and would know what to try changing to get to the color you want.
Old May 28, 2024 | 08:50 PM
Brad, If you are trying to match paint that has been exposed to sunlight and elements for years, what you sprayed would look darker. Body shops have always had to play with paint mix to match repairs.
Let me check with my friend who is a good painter. I talked to him earlier tonight about the Gold paint formula. He is fussy about where he gets his paint.
I had my latest "toy" sprayed 1968 Olds Toronado (1968 H/O) Peruvian Silver. I furnished him the Olds code letter. He has also repainted my 1966 Olds Toronado the original "Ocean Mist".
w30brad's Avatar
Thanks Patton. If I only had a sprayout card of the correct color, my problem would be solved. I would just have the paint shop scan it and make it.
PPG has a Gold that's listed as 'a close match' and I had them mix me a pint and I did a spray out. It's similar (similar to the many photos I've collected of the correct Gold), but it's definitely too dark. This is that sample:
Old May 28, 2024 | 09:07 PM
w30brad's Avatar
Your help is greatly appreciated Ralph, thank you.
Please post a pic of your W-30 if you get a chance!
Here's a shot of mine with the incorrect color (Nugget Gold) stripes
Old May 28, 2024 | 10:23 PM
Here's a shot of mine with the Nugget Gold (ughh...) stripes
Your Nugget Gold stripes are definitely dark. Did you use BC/CC paint on your car ?
Pictures on the internet are not accurate. "Paint chips" in paint manufacturers book are discolored after all these years.
My W-30 Sport Coupe (post) is in the original Black with Gold stripe paint from the factory. I did have the stripes added to the trunk lid when it was about 3 months old. It has only been outside for a very few years in its life. It has been kept inside for at least the last 40 years. I don't think I ever took colored pictures may years ago. Right now, 2 motorcycles, a sewing machine, a riding mower and miscellaneous blocking it in. I may try to get it out this summer.
Old Jun 4, 2024 | 08:51 PM
w30brad's Avatar
Yes, I used BC/CC.
I know I won't find a perfect match on an obsolete paint that was used on stripes on very few cars 54 years ago, but I'd like to get it close. I'm hoping to find an original gold stripe owner who can offer one of these:
  • the paint mix formula
Old Jun 4, 2024 | 09:59 PM
Brad, you have a PM.
Old Jun 29, 2024 | 09:10 PM
w30brad's Avatar
I'm still trying to get this color matched. Appreciate any help, thanks
Old Aug 10, 2024 | 11:38 PM
w30brad's Avatar
With help from one of ClassicOldsmobile's fine forum members (owner of an original paint gold stripe 1970 W-30), I've purchased the gold stripe paint (base coat) for my 1970 W-30.
It's from a company called Kolor Korrect and it arrived labeled as 1970 Olds Gold. They use PPG paint and it's a base coat/clear coat 2 stage. It did not come with a formula or a number, just the name the label. $300 a pint.
I did a spray out card of the Kolor Korrect paint and it is almost identical to the PPG OMNI gold paint base coat I ordered from PPG about 4 years ago. PPG listed that paint as "close" to the original 1970 PPG # 23197 Gold (which they no longer have a formula for). The PPG OMNI info is:
PPG OMNI Base Coat
OEM Code: 55A, WASL8589, WA8589
Description; Gold
I'm going with the Kolor Korrect paint, it's very slightly more "Gold".
Kolor Korrect Spray Out
PPG OMNI Spray Out
Old Aug 11, 2024 | 05:49 AM
69HO43's Avatar
Good for you! You have NO idea how long it took me to convince Demmer to get off their butts to send their sealed up can of 69 H/O Firefrost Gold to DuPont for a remix to base/clear formulation. I still think the conversion formulations don't always end up matching the original lacquer formulations exactly, but sometimes getting it close is all you can do. Obviously the work needed to tweak a color to the exact shade is something the pros can do, but short of that, I think you'll be ok. After all, you're going base/clear anyway, which wasn't done on your car.
Trust me, 99.9% of the people won't even notice. Except a handful of folks here.
Old Aug 14, 2024 | 11:11 PM
w30brad's Avatar
You summed it up perfectly, this will easily be close enough. I've spent countless hours on this thing and it's time to move on.
35olds
Feb 4, 2021 06:32 AM
Madmustard
Paint
Mar 24, 2018 02:23 AM
w30brad
Paint
Mar 20, 2018 01:58 PM
Madmustard
Dec 13, 2017 10:30 AM
