vinyl top repair
Old Apr 29, 2021 | 09:09 AM
holidaysedan's Avatar
vinyl top repair
The original white vinyl top on my '69 Cutlass is 99% perfect, but there's 2 small about 1/4" holes in the corners below the rear window. Does anyone know a a way to repair these or repair kits that are available? Seems to me some kind of vinyl-in-a-bottle stuff could work. Has a
nybody done similar vinyl repairs? I want to save this original top, the car is always garaged.
Old Apr 29, 2021 | 05:13 PM
RetroRanger's Avatar
72 Olds CS
ive used this or similar kit to do some small repairs.
It worked fine i did a couple trial runs first to see how it worked and the results are fine, not unnoticeable if you look but better than damaged material.
The kit I had also had some grain matching cards to find a grain similar to the original grain to blend it better.
I think the only thing that wasnt OK was the sheen of the reprit didnt match the surrounding vinyl. That could probably be remedied w something like armor all or even a clear coat tho.
Old Apr 30, 2021 | 04:21 AM
I've used the 3M kit to repair leather seats. It works well. After the repair there was a darker splotch showing where the repair was done but that could be minimized by matching the color closer.
Old Apr 30, 2021 | 05:14 AM
Thanks, that's exactly the kind of kit I was looking for - will check it out!
Happy Motoring from Roger in NY!
Old May 1, 2021 | 02:47 PM
72455's Avatar
1972 U code Supreme
Any luck Roger?
Cosmic Charlie
Mar 18, 2021 06:00 PM
deathvader
Jan 22, 2021 05:35 AM
midnightleadfoot
Mar 27, 2018 08:57 AM
Cutlass71s
Body work
Apr 16, 2016 02:39 AM
johnnyjaws
Body work
Apr 12, 2014 07:58 PM
