stick on scoops
Old July 5th, 2017, 02:58 PM
willj's Avatar
stick on scoops
hello all, wondering if any one has any sugestions on how to get the stick n scoops of with out messing up paint , thank you . will
willj is offline
Old July 5th, 2017, 04:00 PM
Had me worried for a second there - I thought you were going to ask about installing them...
It really depends on the adhesive used, but I'm guessing this is peel-and-stick foam tape. I'd try heat to soften the adhesive, then remove the residual with paint pre-cleaner. This is available at auto paint stores. Get the solvent-based stuff, not the new water-based stuff. This will remove residual adhesive without damaging the paint.
joe_padavano is offline
Old July 5th, 2017, 07:42 PM
oldolds88's Avatar
try to use the heat on the under side of the hood,itll get the glue warmer sooner
oldolds88 is offline
Old July 5th, 2017, 07:52 PM
Don't overdo the heat or you will bork it.
Koda is online now
Old July 6th, 2017, 08:18 AM
Tedd Thompson's Avatar
You might try denatured Alcohol after the adhesive is hot. Generally alcohol won't effect hardened paint and many adhesives will soften with alcohol..... Tedd
Tedd Thompson is online now
Old July 6th, 2017, 08:20 AM
I've found the paint pre-cleaner to be more effective than alcohol in dissolving adhesives.
Old July 6th, 2017, 08:31 AM
Funkwagon455's Avatar
Some very good suggestions listed above, I might attempt to slide some high test fishing line or spider wire under the scoop flange and slide back and forth while holding constant pressure slightly against the scoop side to get better access to the adhesive tape with removers. Kind of the same way one would remove a windshield.. Really? Stick on scoops?
Funkwagon455 is offline
Old July 6th, 2017, 08:44 AM
damaged442's Avatar
X2 for fishing line!
damaged442 is offline
Old July 6th, 2017, 09:17 AM
TripDeuces's Avatar
WD-40 will remove the adhesive nicely
TripDeuces is offline
Old July 6th, 2017, 09:24 AM
X2 on WD40 or Googone
oldcutlass is online now
Old July 6th, 2017, 02:51 PM
1971 442 conv
Texas442's Avatar
hello all, wondering if any one has any suggestions on how to get the stick n scoops of with out messing up paint , thank you . will
Please excuse my ignorance. What is "stick n scoops"?
Texas442 is offline
Old July 6th, 2017, 02:58 PM
Old July 6th, 2017, 06:42 PM
AWWWMAHGAWD!!!!!
....that's awful. Incidentally, if you make a post in all caps, and nothing else, the software lowercases it for you.
Koda is online now
Old July 6th, 2017, 08:24 PM
steverw's Avatar
I do believe 3M makes an adhesive remover, check with an automotive paint store.
steverw is offline
Old July 6th, 2017, 08:37 PM
Hookers under Hood
76olds's Avatar
Lord Tunderin' geez,
I wonder how many bugs are smeared 'n' pilled on top of each other under them scoops ? Eyeee, better add bug remover to the list
76olds is offline
Oldsproject
December 31st, 2017 12:14 PM
sinclair
Hurst/Olds
March 26th, 2010 01:34 PM
Wyze
December 22nd, 2009 08:56 AM
steve walker
Body work
November 28th, 2009 08:30 AM
70Post
April 21st, 2009 07:48 PM
Quick Reply: stick on scoops
