stick on scoops
It really depends on the adhesive used, but I'm guessing this is peel-and-stick foam tape. I'd try heat to soften the adhesive, then remove the residual with paint pre-cleaner. This is available at auto paint stores. Get the solvent-based stuff, not the new water-based stuff. This will remove residual adhesive without damaging the paint.
Some very good suggestions listed above, I might attempt to slide some high test fishing line or spider wire under the scoop flange and slide back and forth while holding constant pressure slightly against the scoop side to get better access to the adhesive tape with removers. Kind of the same way one would remove a windshield.. Really? Stick on scoops?
