stick on scoops
Old Jul 5, 2017 | 02:58 PM
willj's Avatar
stick on scoops
hello all, wondering if any one has any sugestions on how to get the stick n scoops of with out messing up paint , thank you . will
Old Jul 5, 2017 | 04:00 PM
Had me worried for a second there - I thought you were going to ask about installing them...
It really depends on the adhesive used, but I'm guessing this is peel-and-stick foam tape. I'd try heat to soften the adhesive, then remove the residual with paint pre-cleaner. This is available at auto paint stores. Get the solvent-based stuff, not the new water-based stuff. This will remove residual adhesive without damaging the paint.
Old Jul 5, 2017 | 07:42 PM
oldolds88's Avatar
try to use the heat on the under side of the hood,itll get the glue warmer sooner
Old Jul 5, 2017 | 07:52 PM
Don't overdo the heat or you will bork it.
Old Jul 6, 2017 | 08:18 AM
Tedd Thompson's Avatar
You might try denatured Alcohol after the adhesive is hot. Generally alcohol won't effect hardened paint and many adhesives will soften with alcohol..... Tedd
Old Jul 6, 2017 | 08:20 AM
I've found the paint pre-cleaner to be more effective than alcohol in dissolving adhesives.
Old Jul 6, 2017 | 08:31 AM
Funkwagon455's Avatar
Some very good suggestions listed above, I might attempt to slide some high test fishing line or spider wire under the scoop flange and slide back and forth while holding constant pressure slightly against the scoop side to get better access to the adhesive tape with removers. Kind of the same way one would remove a windshield.. Really? Stick on scoops?
Old Jul 6, 2017 | 08:44 AM
damaged442's Avatar
X2 for fishing line!
Old Jul 6, 2017 | 09:17 AM
TripDeuces's Avatar
WD-40 will remove the adhesive nicely
Old Jul 6, 2017 | 09:24 AM
X2 on WD40 or Googone
Old Jul 6, 2017 | 02:51 PM
Texas442's Avatar
1971 442 conv
hello all, wondering if any one has any suggestions on how to get the stick n scoops of with out messing up paint , thank you . will
Please excuse my ignorance. What is "stick n scoops"?
Old Jul 6, 2017 | 02:58 PM
Old Jul 6, 2017 | 06:42 PM
AWWWMAHGAWD!!!!!
....that's awful. Incidentally, if you make a post in all caps, and nothing else, the software lowercases it for you.
Old Jul 6, 2017 | 08:24 PM
steverw's Avatar
I do believe 3M makes an adhesive remover, check with an automotive paint store.
Old Jul 6, 2017 | 08:37 PM
76olds's Avatar
Hookers under Hood
Lord Tunderin' geez,
I wonder how many bugs are smeared 'n' pilled on top of each other under them scoops ? Eyeee, better add bug remover to the list
Oldsproject
Dec 31, 2017 12:14 PM
sinclair
Hurst/Olds
Mar 26, 2010 01:34 PM
Wyze
Dec 22, 2009 08:56 AM
steve walker
Body work
Nov 28, 2009 08:30 AM
70Post
Apr 21, 2009 07:48 PM
