Trunk lock not working
Old Mar 14, 2014 | 06:05 PM
71 Cutlass Ragtop's Avatar
Angry Trunk lock not working
We just picked up the deck lid from the paint shop. While we were aligning the fit and we closed the trunk we could not open it again. The key turns, but it will not unlatch. I'm not sure if it makes more sense to try and remove the rear seat or just keep trying to work the lock. This is a convertible if that helps out. Thanks, everyone!
Old Mar 14, 2014 | 06:41 PM
2blu442's Avatar
I've never done this in a convertible, but I have pulled the rear seat in a hardtop and using about 4 feet of extensions removed the bolts that hold the latch to the trunk floor. I've found that's the easiest way to open the trunk without a key or a latch with problems.
It could be that the latch isn't properly aligned so its not releasing. Or the rod from the lock to the latch may not be in place, that would disconnect the lock from the latch.
Good Luck and let us know how it works out.
John
Old Mar 14, 2014 | 07:01 PM
This deck lid has become one thing after another. I'll see if I can't get the rear seat out and reach the bolts........Thanks, John!
Old Mar 14, 2014 | 07:59 PM
Kennybill's Avatar
I've drilled them from the outside. Mask of around the lock, overkill is good. I started with a small bit moving up to a larger. The cover will pretty much fall apart. Screwdriver will turn it open. Spring clip holds the lock assembly in place. Rock Auto sells lock assembly cheap. Good luck, Ken
Old Mar 15, 2014 | 09:56 AM
CRUZN 66's Avatar
Olds Fever
If you can't feel any tension on the key as you turn it, most likely the rod has become detached from the lock cylinder..... If you do feel tension try pushing down and/or pulling up on the lid, that may release the latch if it is only stuck.....
Old Mar 15, 2014 | 12:23 PM
mrolds69's Avatar
x2 what cruzn66 said. Turn key and see if you can pull it up.
Old Mar 22, 2014 | 05:20 PM
I finally managed to open the trunk. After getting the rear seat out and removing a speaker I was able to use a four foot broom stick with a flashlight and a screwdriver taped to the end of the stick to open the trunk. I have attached a picture of the rear support with something in the center of the picture that I do not recognize. Does anyone know what this is? Thanks again for everyone's help!
Old Mar 22, 2014 | 05:49 PM
don71's Avatar
same but different
Glad you got it open.
That thing is called a stand pipe...It allows fuel vapors to return to a liquid and back to the tank. Its part of the emissions equipment.
Old Mar 22, 2014 | 05:50 PM
That's the fuel evaporation standpipe.
edit: You beat me, Don!
Old Mar 22, 2014 | 07:12 PM
As others have mentioned. Whatever you do, don't unbolt this. It's got 4 hose connections on the bottom of the kick up panel. 3 of them are attached to the fuel tank, one is attached to the emissions line. Here's a picture of it from the bottom
Old Mar 23, 2014 | 02:26 PM
Cool, once again, "Thanks!"
goldie442
Aug 21, 2015 11:01 AM
71 Cutlass Ragtop
Apr 17, 2015 08:42 AM
heritageadam
Apr 14, 2013 05:25 PM
randomarrival
Dec 22, 2012 12:28 PM
old98owner
Jul 13, 2010 05:35 AM
