Tighten outside mirror?
Old Oct 30, 2020 | 12:47 PM
Jon442's Avatar
Gearhead
Is there a way to tighten the head on this kind of mirror?
Old Oct 30, 2020 | 01:40 PM
You can try and pry the glass out and see.
Old Oct 30, 2020 | 02:40 PM
Knew a guy who took some G-U-M floss toothpicks & inserted them (then cut the ends off) from the back to tighten the ball. Doesn't sound very fancy but it worked none-the-less. I would even think some of those skinny toothpicks might work.
Old Oct 30, 2020 | 06:56 PM
JohnnyBs68S's Avatar
Chief has some good ideas. I was "lucky" and the glass broke in mine, allowing me to replace the loose rivets on the ball tensioner bar with screws before installing the new mirror. Been holding for ~35 years.
Old Oct 31, 2020 | 07:53 AM
RetroRanger's Avatar
72 Olds CS
Johnnys post reminded me long ago i had a similar type mirror that was loose and was able to tighten up with the glass removed bt bending the plate that applies pressure to the ball.
if its a repop you my need to replace that piece w something better.
Kajun442
Jan 2, 2021 05:47 AM
My2nd 69 442
Nov 14, 2017 05:20 PM
anthonyP
Sep 5, 2017 11:44 PM
My2nd 69 442
Aug 13, 2017 06:23 PM
blunce
Nov 20, 2012 03:06 AM
