T tops Help
Old May 11, 2011 | 04:18 PM
paul879's Avatar
69-72 olds owner
T tops Help
Can annyone help me how to support the rails ,I just bought A 1975 hurst olds w/T tops past owner had the roof repaired with new sheet metal but body shop removed the supports around the edges .Need to know were the support braces go and if they are supposed to be between the top and inside metal and were they should be welded if need be I will take pics if annyone has to see what i mean thanks
Old May 11, 2011 | 05:53 PM
69442C's Avatar
Send a few photos and I'll see what I can do to help you. I completely replaced a set of Hurst t-tops a couple of years ago on a 79 HO restoration and your 75 t-tops should just about be the same thing.
Old May 14, 2011 | 07:17 AM
69442C's Avatar
Paul879, I received an email on this thread where it appears you tried to post a picture......? I was not able to open whatever it was that was but the odd thing is that information does not appear in this thread. Anyway, if you were attempting to send something, just reply to this thread again, post the photo(s) to the thread and explain the issue as you show it in the photo and I'll see what I can do to answer your questions.
75hurstoldsW-30
Jun 20, 2021 10:10 PM
1966toro
Feb 4, 2019 08:36 AM
oldspackrat
Oct 2, 2013 03:50 PM
junkyardbob
May 29, 2007 06:47 PM
dyscookn
Mar 8, 2007 04:41 AM
