Removing oxidation from black
Old Mar 9, 2011 | 08:33 AM
texasred's Avatar
Tom Servo's Stunt Double
I have a lot of black underhood parts that have a grey oxidation on them. Some are large or unavailable to paint (AC Compressor and brackets,etc) that I can't just throw in a blast cabinet. Rust is not a problem here...just the "greyness".
Any special tricks or products to restore the black as non-invasively as possible?
TIA
C.J.
Old Mar 10, 2011 | 02:01 AM
D. Yaros's Avatar
That oxidation should be able to be removed without harm with a little paste wax.
Old Mar 14, 2011 | 07:25 PM
1967bigdaddy's Avatar
Just spray some No Touch Tire spray on the parts and let it sit for a few minutes then wipe it down.
Old Mar 14, 2011 | 07:26 PM
Or you can used compressed air to blow it off the parts, to make it even easier.
Old Mar 15, 2011 | 02:19 AM
Bluevista's Avatar
Registered
It's paint like the outside of the car so treat it the same way for oxidation.
I'd use Meguirs #2 fine cut cleaner and if it looks too rough when that's done follow it up with #9 swirl remover, they can both be used by hand.
It's like rubbing out paint so it's going to increase the gloss whatever it is.
4speed455
May 29, 2017 06:38 AM
Stefano
Nov 26, 2014 11:23 AM
Magna86
May 12, 2014 05:14 AM
capstoneclub
Mar 27, 2014 10:15 AM
Vader
Jan 7, 2012 05:12 AM
