Rear Tires Too Big! Help
Old Feb 3, 2015 | 08:40 PM
Darrens70Cutty's Avatar
I just put some Hoosier Pro Street Tires on my 1970 Cutlass Supreme. The rears are 31X12.5-15 and look awesome but I know when I get my car running their going to rub. I bought them from jegs and since I already mounted them they wont let me return them. The fender to the tire is just a fingers length apart.What is my best bet, I'm definitely on a budget but need them to fit! Any advice would help. Thanks
Old Feb 3, 2015 | 09:27 PM
What wheels are they mounted on? Could be incorrect backspacing.
Old Feb 4, 2015 | 05:16 AM
rustyroger's Avatar
'87 Delta 88 Royale
I can think of four options that might work;
Change the wheels for some with different back spacing (so long as the tires don't rub on the inside.....).
Flare out the fenders.
Jack up the suspension to get extra clearance.
Replace the tires with one that fit.
I can't help wondering why you bought the tires without first checking if they would fit?.
Roger.
Old Feb 4, 2015 | 05:33 AM
Oldsmaniac's Avatar
You could trim some of the inner lip of the wheel well off. There may be an inch or so you could trim and still retain the molding.
Old Feb 4, 2015 | 06:13 AM
Professur's Avatar
Just do a couple of good burnouts. That'll rub off the extra and then they'll fit.
Old Feb 4, 2015 | 07:52 AM
Yup. In the old days, you'd just take a Sawz-All to it, then use some Bondo to create a new arch.
Or you could put those tires up for sale, recoup some of your loss, and buy a smaller pair.
Old Feb 4, 2015 | 08:19 AM
Oldsmaniac's Avatar
Well I didnt mean to get that drastic, just the inner lip that usually has more metal than necessary. Yeah I remember those days...wide deep dish wheels and air shocks to keep the tires from rubbing!
Old Feb 4, 2015 | 08:40 AM
Yeah, that's kind of what I meant - before these cars were "old," people (especially racers and guys who wanted to install huge tires) used to just hack the bejeezus out of them, then scrap 'em when they'd had their fun (usually after a "close encounter" with a telephone pole or a tree).
Old Feb 4, 2015 | 09:13 AM
Grumbler's Avatar
Monroe air shocks and shackles! That's how we did 'er in the street freak days
Old Feb 4, 2015 | 09:37 AM
Shackles?
Old Feb 4, 2015 | 09:49 AM
Grumbler's Avatar
Shackles. The dumb way to lift your car, put extensions in the leaf springs where they attach at the back end
Old Feb 4, 2015 | 10:10 AM
But Cutliï don't have leaf springs.
Old Feb 4, 2015 | 10:14 AM
Grumbler's Avatar
I wasn't being serious, just reminiscing on the way it was
Old Feb 4, 2015 | 10:24 AM
Yup. All the Novas and MoPars had the lift shackles.
The GM guys just went to the junkyard and bought station wagon springs.
Old Feb 4, 2015 | 10:26 AM
Professur's Avatar
My wagon has coils
Old Feb 4, 2015 | 10:40 AM
Grumbler's Avatar
So did my Javelin. And the Monroes. I chewed the outer edge off the tires when the back end settled down after the air line let go lol.
Not too smart in those days.............
Old Feb 4, 2015 | 10:47 AM
So did my Javelin.
Ha ha. My wife had one of those back in the day.
I think she got dragged out of more than one ditch in it.
Back then, you could run it off the road, get dragged back on, and be on your way again before you even started to sober up.
Old Feb 4, 2015 | 11:05 AM
RetroRanger's Avatar
72 Olds CS
Aw right ya think you can make it home with out hitting anything else ?
Good now get going!
Old Feb 4, 2015 | 01:16 PM
Bernhard's Avatar
1. Check if there is room for the tire on inside frame to tire.
2.If there is enough room to move the tire inward back spacing is the way to go.
3. If you have maxed out your back spacing you can mark the inner wheel well lip and grind about a half inch extra clearance until you hit the screws that hold the trim on.
I always marked the inner lip with a felt pen and ground to the mark. A small sliding square works well to keep the line even when laying out the grinding line.
I also liked to protect the molding with masking tape.
4.Sell the tires for a smaller set
Good luck
EightballZ
Aug 24, 2015 04:56 AM
RSmith8
Nov 1, 2013 02:22 PM
snowballs442
Dec 16, 2010 03:07 AM
agtw31
Jul 20, 2009 09:58 AM
69cutlassgirl
May 24, 2006 10:07 PM
