Ready for paint
Old Mar 17, 2021 | 05:17 PM
DPanke's Avatar
Ready for paint
My 71 Cutlass Supreme convertible is 50 years old this year. I want to have it painted, how do you remove the Olds letters on the trunk? Thanks - Dennis
Old Mar 17, 2021 | 06:42 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Evenly pry with a plastic tool and use a backer of plastic or wood wide enough to not transfer the leverage load directly to the lid. They should easily pop out but some can be stuck thus the recommended use of a backer...
Here is an example:
https://www.eastwood.com/12-pc-trim-tool-set.html
Buy spare barrel nuts.
Be aware after the car is painted you may need to rat tail out the holes. Brush paint into the filed holes let it dry then insert the letters.
Run zinc-rich primer in the trunk lids lower sheet metal seam before paint to give it some rust protection. It's a known bad spot on 68-72 A body lids.
Old Mar 18, 2021 | 03:49 PM
DPanke's Avatar
Thank You!
oldsonharmont
Body work
Oct 17, 2018 06:14 PM
Al Graaf
Paint
Jan 26, 2015 06:12 AM
chip-powell
May 6, 2014 07:32 PM
kbdecatur
Jun 12, 2012 05:06 AM
boedingan
Mar 29, 2006 08:09 PM
