Quarter window trim piece problem
Old September 11th, 2013 | 09:14 PM
Hoffman2099's Avatar
Hi, my driver side quarter window trim piece fell off the window and I was going to use some glass setting tape to reinstall it but had some questions first. Should I buy 3/64" tape or get some 1/32"? Do I have to take the quarter window out to install the chrome trim properly? Anybody have any pointers on how to do it? Thanks
Old September 11th, 2013 | 11:54 PM
Charlie Jones's Avatar
Phantom Phixer
What model and year is your car? Probably the best source of assembly / disassembly info is the factory shop manual.
Old September 12th, 2013 | 05:32 AM
brown7373's Avatar
You don't need to remove the 1/4 window. I just put a new one on and used black GE Silicone to install it. Once it sits 24 hours to cure, it is very difficult to remove. It also seals out water from geting behind the rubber and rusting. My original lasted 41 years. If this one matches that, I'll be 104 years old.
Old September 12th, 2013 | 06:36 AM
ROCKET VAPOR's Avatar
Lance
IIRC, I used 1/32" thick rubber pond liner material. The clean rubber gripped great. Trimmed off the extra material after the chrome channel was fully seated. I used a rubber mallet and a block of wood to set the chrome trim with the window still installed (only because this was found after the car was done).
This black soft rubber was very similar to the black gasket material used at the factory to set this chrome piece.
art72
May 8th, 2013 05:17 PM
defiant1
March 8th, 2012 06:27 AM
Indy_68_S
Brakes/Hydraulic Systems
January 2nd, 2011 09:23 AM
Jaybird
April 27th, 2010 10:10 AM
kenrod
April 14th, 2010 05:45 PM
Quick Reply: Quarter window trim piece problem
