Order of painting engine, bay and exhaust manifolds
Old Apr 9, 2021 | 08:08 AM
Matthew Saliba's Avatar
I have everything prepared for paint. Cleaned, wire wheels, rust and oil free surfaces.
What order is best? 1.Bay 2.engine 3.exhaust manifold???
1950 98. Using Bill Hirsh engine enamel in correct green, vht very high heat cast iron finish for manifolds, and high heat satin black rust oleum for the bay/firewall
Old Apr 9, 2021 | 08:36 AM
Is the engine currently installed in the vehicle? If so, use aluminum foil to block off the areas that you aren't painting and I would do it in the following order 1) engine 2) engine bay. The exhaust manifolds should be removed to paint them. Ultimately, I think you will be bummed about that VHT Superhot. Especially if you try to paint the manifolds when they are installed. The paint will bake off pretty quick. I used it and it wasn't very durable. Do you plan to brush paint the engine and engine bay?
Old Apr 9, 2021 | 08:42 AM
Thanks. I already foiled everything. I intend to brush as all is in the car and connected including exhaust manifolds. I figure I will try the vht and if it burns off so be it. It is specifically for heaters so would think it would hold. I wire wheeled the manifolds so nice was thinking not even to paint and since painting while they are attached it is a quick and easy job. Using foam brushes and reg brush for tight to reach areas.
Matthew Saliba
Dec 10, 2022 05:34 AM
rick442
Feb 22, 2018 12:43 AM
EngineErnie
Jul 9, 2017 10:26 AM
47 Convertible
May 19, 2012 04:00 PM
bittersweet71
Paint
Jul 9, 2009 07:48 PM
