G-Body Mldg Clips
G-Body Mldg Clips
I recently had a request for Part Numbers for the Molding Clips attaching the BX2 (wide) Chrome Trim on G-Body Coupes and thought maybe others would like to have the same information for their records. I have also included front windshield and back window clip info. The following is a list of part numbers, where they are used, and how many are required. I also included vinyl top trim clips... Some may still be available from GM dealers or through GM dealers (VPI):
G-Body Mldg Clips………….
12338162 - Front Fender Lower Rear ( 2 )
22510423 - Front Fender Lower Front (LH) ( 2 )
12338009 - Front Fender Lower Front (RH) ( 2 )
20224695 - Front Door Lower Front (RH) ( 1 )
20224696 - Front Door Lower Front (LH) ( 1 )
20671768 - Front Door Center (AR)
20222491 - Front Door Lower Rear ( 2 )
20222397 - Rear Quarter, Rear of Wheel Opening Lower (RH) ( 2 )
20222398 - Rear Quarter, Rear of Wheel Opening Lower (LH) ( 2 )
22506785 - Rear Quarter, Front of Wheel Opening (AR)
3066259 - Back Window Lower to Panel ( 8 )
9891400 - Back Window Reveal Mldg, Upper & Sides (AR)
20603072 - Front Windshield Upper & Sides (Can also be used for the back window) (AR)
VINYL TOP MLDG CLIPS
The side clips are PN: 20298166 (6 req'd) & the roof panel clips are PN: 12337978 (6 req'd). The Belt molding clip is PN: 20175051 (as req'd), and the back window belt molding clip is PN: 20218415 (6 req'd)....
Good info for sure. Trying to gather them up for my '79 Cutlass. Even with parts books it can be a challenge finding the correct ones.
