Feather fill G2 question
Old Jul 31, 2010 | 12:30 PM
B-Mann's Avatar
I am priming my car with the feather fill G2 high build primer, and on their site it says that it doesn't need a sealer before the topcoat. On another forum I was reading where guys were saying it needs a sealer before paint. Does anyone have any info on what way I should go. Thanks
Old Jul 31, 2010 | 04:17 PM
Blk71SX's Avatar
who would know better about the requirements of the product than the manufacturer?
Old Jul 31, 2010 | 05:14 PM
B-Mann's Avatar
That's kinda what i thought but I would bet that they all know more than me and i don't want to have to go back and redo everything lol. Just wanted some opinions.
Old Jul 31, 2010 | 10:28 PM
70Post's Avatar
You should probably also approach it from another "angle"...ie...what does the PAINT MANUFACTURER (topcoat) recommend under their paint?????....or what do they PREFER given the options.
Old Aug 1, 2010 | 04:28 PM
ijasond's Avatar
Purveyor of Polyurethane
It doesn't need to be sealed, assuming that you finish with 600 grit paper(or finer) and don't sand through to expose the metal or filler underneath.
Old Aug 1, 2010 | 04:34 PM
B-Mann's Avatar
Thanks, i will post pics after the job is done of before during and after paint.
Old Aug 3, 2010 | 06:29 PM
442_Mustang's Avatar
Also, when blocking feather fill, do not sand through it to the under coat of primer or it will "Ring"(Leave a mark where the sand through occurred)
Old Aug 3, 2010 | 06:32 PM
gbodyfan's Avatar
you shouldnt need sealer as long as you sand with 600 or finer and dont cut threw but but i would just for a little insurance on hiding especially if its a dark color
Old Aug 3, 2010 | 07:04 PM
ijasond's Avatar
I'm not a fan of feather fill. I've found block sanding large areas of it to be quite a miserable experience. If possible I'd go with a high build urethane primer or a sandable epoxy. Kirker makes a very affordable, sandable epoxy primer.
72cuttys
Drivetrain/Differentials
Jun 6, 2014 02:55 PM
capstoneclub
Mar 20, 2014 02:44 PM
cutlass66
Jan 22, 2013 02:17 PM
344870M
Apr 11, 2009 08:55 AM
Lou
Apr 19, 2008 06:19 PM
