Edge of trunk replacement
Old Sep 1, 2021 | 05:09 AM
Hi everyone.
I have a 70 Cutlass convertible and the bottom lip of the trunk edge, where the weatherstrip goes, has rusted through. EVERYBODY knows the convertible uses the 4 door trunk lid, so my question is, do I cut that piece out of a 4 door, or can I get it out of a regular Supreme, or should I just seek out another convertible I can cut it out of? The obvious choice would be another convertible, I know, but I'd like to have some options.
Thanks everyone.
Old Sep 1, 2021 | 05:37 AM
Tri-Carb's Avatar
Just in case you do not know, the trunk gutter channel metal is reproduced by Belden Speed. If you are replacing a straight section you may want to consider it.
http://www.beldenspeed.com/beldenspe...erchannelstock
Old Sep 1, 2021 | 06:53 AM
Thanks I'll check them out.
Old Sep 1, 2021 | 07:45 AM
Oldsmaniac's Avatar
So if you can find a 4dr trunk lid why not just use the whole thing? ok got it now you need the channel...
Old Sep 1, 2021 | 08:31 AM
akspeedy's Avatar
Thanks this is very good info to have!!!
Old Sep 1, 2021 | 09:40 AM
tkcutlass's Avatar
The Belden channel stock worked out well for me.
Old Sep 1, 2021 | 11:59 AM
Sweet. Without looking I don't recall if the damage goes around the curve or not, but it does say it can be [I don't remember what they called it, triangled or something like that] and bent around the curve. Never even heard of this place, thanks Tri-Carb.
Old Sep 1, 2021 | 12:54 PM
tkcutlass's Avatar
depending on how much rust you may need to create a companion piece
Old Sep 1, 2021 | 01:30 PM
Mike,
The difference between the 4 door / convertible lid and the hardtop Supreme lid is the forward corners. The 4 door / convertible corners are rounded, whereas the hardtop Supreme corners are square. One of the local Olds club members transformed a regular Supreme lid into a 'vert lid for his '71 by grinding and mig welding those corners. So the channel would be the same.
Old Sep 1, 2021 | 01:47 PM
BackInTheGame's Avatar
Another outfit, called Rust Replace, has that channel as well. It may be the same stock.
Old Sep 1, 2021 | 03:18 PM
What I found when I logged into Belden Speed Shop was they created a new website, RustReplace.com so they are one and the same.
Here I was sweating having to get this piece fixed, sounds like it will be a fairly simple task. I'm not going to do it, but it doesn't look like I'll have trouble hiring someone to do it.
Old Sep 1, 2021 | 03:33 PM
RetroRanger's Avatar
72 Olds CS
Looks like TKcutlass has the skills
Old Sep 1, 2021 | 04:38 PM
What I found when I logged into Belden Speed Shop was they created a new website, RustReplace.com so they are one and the same. .
Ah, the twisted (inter-)webs that are woven! Glad it's working out for you!
Old Sep 2, 2021 | 08:21 AM
Andy's Avatar
Nice fitting and replacement job on the channel, I used to weld for a living, heavy oil field equipment so I plan on doing some work on my car with fabrication and metal replacement..great job
sx455raidercelticfan
Apr 10, 2020 03:41 PM
slantflat
Sep 27, 2016 03:55 PM
Ryan McManus
Jan 25, 2015 04:05 PM
shamusj
Dec 19, 2013 03:01 PM
Mark71
Jun 20, 2011 10:06 PM
