Door glass mounting stud and slider ball for a 71 Delta...where to find?
Hey guys I'm still working on reassembling this 71 Delta 88...getting closer. I'm hoping to get most of the interior back in this week and next. I almost finished installing the glass in the car today but I ran into a snag on the last window. During disassembly the passenger front window had broken and somewhere along the line over the last few years of it being apart I lost two of the pieces that bolt onto the glass.
One is the standard glass mounting nut and stud but it's the longer style that gets a regular nut on it as well to attach it to the window regulator assembly. The other is this plastic half sphere that goes on the front and keeps tension on the window as it raises and lowers. I don't even know what it's called.
Does anyone know where I can get either one? The nut/stud I believe is different than most of the older GM ones as the studs were shorter on those. What other cars had this type of window assembly?
I used to have a 72 convertible, and still have the front glass. I will check for you and see if the mounts are still attached.
If I don't have it , try sending a PM to dedsleds on here. He has had a lot of full size cars come through his shop over the years.
costpenn
October 4th, 2014 04:39 AM
