Bumber adjustments
Old Aug 12, 2024 | 11:21 AM
Nick I's Avatar
Bumber adjustments
Hi all! I was wondering about bumper adjustments on a 68 442. My front bumper is pitched out/up on the bottom and my rear bumper looks like it needs sucked forward a bit. I was wondering which bolts out of all of them I should loosen to achieve what I need for each.
I think the rear is pretty straight forward, but I'm not sure if I should leave it or try to get it tighter.
For the front, I loosened the support arms at each end, but not sure which main bolts to loosen or if i should loosen all of them.
Pictures of my current situations included.
Front right
Front left
Rear right
Rear left
Old Aug 12, 2024 | 05:55 PM
442man$'s Avatar
It's the bumper brackets to frame bolts you need to loosen.
Old Aug 12, 2024 | 06:15 PM
Nick I's Avatar
I'll start there, thanks!
Old Aug 12, 2024 | 06:32 PM
I've done this numerous times. Suggestion - use a floor jack or two (better). Form/Fashion 2x4s or whatever material of your choosing (I've also used roofing shingles). Loosen the hardware, support the bumper with floor jack(s) and you can get darn handy with making adjustments.
Old Aug 12, 2024 | 06:55 PM
Nick I's Avatar
Great suggestions, thanks! Im not a body guy. Anything else automotive wise I'm game for and pretty good at. Just not body work, even as simple as this ha ha.
1972code26
Nov 24, 2023 01:54 PM
deaddds
Jun 13, 2022 07:34 PM
jk828
Jun 14, 2021 06:56 PM
boeseberta
Oct 6, 2014 02:06 AM
oldsguybry
Jun 3, 2013 07:05 AM
