Broken Body Mount
Broken Body Mount
I am wondering if any of you have any suggestions on how to repair a body mount on my cutlass convert. The nut broke loose and is spinning inside the body channel. It is the # 5 mount behind the axle on the right side. I have some idea but they all involve cutting and welding. Hoping someone has a simpler solution.
If the cage nut is spinning not sure there is a way without cutting?, there isn't even room to reach up and try to tack weld a spot. The good news it is in the trunk, you could perhaps cut 3 sides of a square bend it up, then after you just bend it back down and weld it shut, I suppose you could use a hole saw, and an appropriate size body plug they are rubber but it isn't ,correct, but will work, look at gear head,s thread on his convertible he fixed a few , sorry couldn't be more help.
