Body Glue????
Old Mar 25, 2010 | 11:23 AM
Ranzan's Avatar
Getting There
Body Glue????
I have never used this stuff and was wondering what your guys thoughts were on it
I`m thinking it might be a better seal on my rear filler panel where it meets the sail panel area? then use some seam sealer over that?
or just spot weld the whole panel in
Still plan on spot welding the front and rear of the panel
Old Mar 25, 2010 | 12:19 PM
67 Cutlass's Avatar
When you're happy with the fit up of the panel, clamp it under the sail panels in several spots and weld up the holes from drilling/grinding the factory welds.
Get a spray can of weldable primer and spray the hidden areas before welding. Welding supply store or auto paint shop should have it.
Right or wrong, that's how I did it.
Besides, I didn't know body glue existed. Is it some kind of epoxy?
I haven't seam sealed the visible joints yet but the way I understand, it gets sealed after primer and before paint.
Old Mar 25, 2010 | 12:43 PM
Ranzan's Avatar
Getting There
Mike
I`ve been reading up on panel Glue or adhesive... it seems to be really good stuff but since I have never used it I thought for that one paticular area it might work better
My panel is dead on now.. I had to take a small 1/8 out of the rear gutter channel . It seems it was rocking in the center of the gutter
only bugger for me is I now have to fab up an upper section of gutter channel right on the corners since mine didn`t have them
I used my flat sheet metal visegrips along the sail panel area... brought everything dead tight with 3 per side
Old Mar 25, 2010 | 01:00 PM
flatoz's Avatar
not sure on the stuff your using, but look up sikaflex, I think its a german product, used basically to 'glue' alot of the modern cars together, I was looking at a newish bmw at a panel school I was doing a course at and the guy was telling me they teach the apprentices how to 'glue' the chassis rails back together with this stuff.
it sets with the moister in the air, apparently fantastic stuff and as strong as a weld.
as for your application, I can't say, but look into it, it might be what you need. I have some to use to glue a fibreglass A model floppy body to the steel frame I have made, just haven't done it yet. use to use bog, going to give the sikaflex a go.
Old Mar 25, 2010 | 01:25 PM
Nilsson's Avatar
These glues are great for panels as well as door skins and many other non structural applications.
Old Mar 25, 2010 | 02:25 PM
Ranzan's Avatar
Getting There
and one other thing which brands are good....
flatoz thanks for the info
Old Mar 25, 2010 | 02:52 PM
Nilsson's Avatar
3M and SEM..........and I am sure there are a hundred others.
Old Mar 25, 2010 | 03:36 PM
RAMBOW's Avatar
Ben
Wes- talk to Dave over on the TCNW site- he has done quite a bit on his car using the panel adhesive- And BrettD used the adhesive in the exahst same way you are planning on your filler panel when he did the filler on his 66 last fall.
There are a ton of pics of bretts filler project over on TC in the bodyshop forum. Very useful.
Old Mar 26, 2010 | 05:35 AM
Ranzan's Avatar
Getting There
Thanks for the info guys.....I`ll be hitting the parts store to see if they carry it
Ben thanks for the thread tip it was a good read
Old Mar 26, 2010 | 06:11 AM
stan 65 cutlass's Avatar
hey wes, the bodyshop up the road uses glue only on quarters, he likes it cause theres no more welding or warping. ill have to stop by sometime see your progress. stan
Old Mar 26, 2010 | 06:29 AM
Ranzan's Avatar
Getting There
Stan come on up anytime coffee is always on till 3 then we switch to beers
Old Mar 26, 2010 | 06:47 AM
Eric Anderson's Avatar
I agree its good stuff, you will need a two part gun and the mixing tips but the stuff holds like a weld and seals the seams, also it was reccomended to me to use the slower setting stuff as it's a little more forgiving to get your panels lined up and clamped in time(at least for a rookie like myself.) I think I still have some out in the garage from when I was working on my truck I'll check the brand for you it worked out great but I'm sure they all probably do.
Old Mar 26, 2010 | 06:59 AM
seems to me i'll be in the area after 3, i get enuogh coffee in the morn.the storys are always better with beer. have a job in bowser next week maybe.going to see some 65 parts today in vic. sounds promising. stan
Old Mar 27, 2010 | 04:20 PM
70 cutlass s's Avatar
Found this on youtube about it.
http://www.youtube.com/watch?v=AXrGJ_D4CWg
jvock6
Body work
Apr 8, 2012 06:52 AM
auto_editor
Mar 23, 2011 05:56 PM
toro455
Jul 2, 2010 05:19 AM
jensenracing77
Apr 5, 2010 01:48 PM
ztim
Jan 18, 2008 06:47 AM
