any painters out there
Old Dec 19, 2009 | 08:18 PM
semper-fi's Avatar
proud owner 69 olds
ok i just fixed the body dammage on my 442 and layed down the primer ok now what is my next step should i sand the primer so it is smoth if so do i sand a little each step like the primer the base and clear and what size of sandpaper do i do it with and any other tips would help i have to have this care finished in 3 weeks for the car show thank u
Old Dec 19, 2009 | 09:32 PM
HolidayCoupe's Avatar
400 grit sandpaper should do and make sure you use guide coat
Old Dec 20, 2009 | 06:03 AM
jj1965's Avatar
Use a long sanding board with the quide coat, as long as possible, this will help to reveal imperfections in your body work. If on a curved surface use a flexible sanding board or pad. I agree 400 grit should be good. Good luck!
Old Dec 20, 2009 | 06:10 AM
I'm trying to learn this also. Here's a thread I've been watching
https://classicoldsmobile.com/forums...wighlight.html
dave1978
Jan 9, 2021 07:13 AM
Zrzoun
Aug 16, 2015 08:45 AM
chip-powell
Jul 31, 2013 06:14 AM
Guitar40
Jul 15, 2012 10:02 PM
Nailhead 88
Jan 8, 2008 05:20 AM
